-   Restorations & Upgrades (https://www.offshoreonly.com/forums/restorations-upgrades-285/)
-   -   32 Skater Rebuild (https://www.offshoreonly.com/forums/restorations-upgrades/359266-32-skater-rebuild.html)
Rossman 02-25-2019 06:46 PM
32 Skater Rebuild
Ive got another thread in the Skater section but there doesnít seem to be much happeniní over there. Figured I would get some more eyes and advice over here and seeing on how there is a couple of other ď32Ē cat builds going on at the moment it might be fun to watch all three progress.
Bought the boat in the spring of 18í after selling my 32í Velocity from the east side of Michigan. Came as a trailer, hull, and Bravos on IMCO boxes. Learned quite a bit of info from a few OSO members which was helpful and fun to acquire some more history on the boat. The plan is to ditch the Bravos, go to Arnesons, and Iíve got some older merc 700SCís I am going to put in for the time being. Ditch the tri-axle leaf sprung duallie setup with out dated brakes and a bent axle for a tri-axle torsion single tire set up. Add a drive guard and new lights, paint, etc. I am thinking some sort of tunnel extension and bustle to cover the drives. I also plan on some sort of wrap around windshield or 1/4 canopies. Progress on the boat may be slow at times as I work out of town for weeks on end. Enjoy!
https://cimg9.ibsrv.net/gimg/www.off...7dfd73c82.jpeg
https://cimg6.ibsrv.net/gimg/www.off...2f6091421.jpeg
https://cimg8.ibsrv.net/gimg/www.off...7b6d29ac7.jpeg
https://cimg7.ibsrv.net/gimg/www.off...bf257ef98.jpeg
Rossman 02-25-2019 06:49 PM
Rossman 02-25-2019 06:55 PM
I believe (aswell at Pete) that it was an original Skater trailer. A company in California converted it to the tri-axle duallies for whomever owned the boat at the time. Havenít a clue why. I think itís horrible ugly and way over kill. Removed axles, replaced outside tubes, started working on drive guard, put some steps on the front, cleaned some old welds up, put a new tongue on it, and some other odds and ends
https://cimg9.ibsrv.net/gimg/www.off...d44063896.jpeg
https://cimg7.ibsrv.net/gimg/www.off...c9ba74191.jpeg
https://cimg8.ibsrv.net/gimg/www.off...358bb9393.jpeg
https://cimg5.ibsrv.net/gimg/www.off...c3c48a386.jpeg
https://cimg1.ibsrv.net/gimg/www.off...5167d88db.jpeg
https://cimg4.ibsrv.net/gimg/www.off...25747e162.jpeg
https://cimg2.ibsrv.net/gimg/www.off...8b81f10c3.jpeg
https://cimg3.ibsrv.net/gimg/www.off...11f8f94fa.jpeg
Rossman 02-25-2019 06:58 PM
Rossman 02-25-2019 07:07 PM
Rossman 02-25-2019 09:21 PM
Test fit the boat on the trailer and realized it was too high. By a long shot. I ordered 45* down angles on the torsion axles and should have ordered 0*. Iíve got a couple different ideas to lower it but winter had finally hit in Michigan and I didnít want to haul it back and forth to work on the over salted roads and have a rusted out trailer before paint so it sat under the boat in the barn. I took the axles out from underneath of it so I had enough height clearance to try and rig some motors. I initially was going to run the boxes and bravos but found a smokin deal on some surface drives and love the concept and idea of them. My father has a 40í skater with ASD 8ís and I like the simplicity, strength, and hydrodynamics of the drives. I ran down to Skater and got some motor mounts from Pete and fit them in the boat. To get the minimum amount of angle on the driveshafts I had to move the motors over an inch and three quarters and down two inches. I have not received the ASD 7ís yet but I think if anything I will be able to mount the motors even lower and keep them where theyíre at side to side.
https://cimg9.ibsrv.net/gimg/www.off...15c1bc150.jpeg
https://cimg7.ibsrv.net/gimg/www.off...e85862337.jpeg
https://cimg8.ibsrv.net/gimg/www.off...6c138810c.jpeg
https://cimg0.ibsrv.net/gimg/www.off...da0123aa8.jpeg
https://cimg1.ibsrv.net/gimg/www.off...e891204cd.jpeg
Rossman 02-25-2019 09:35 PM
https://cimg2.ibsrv.net/gimg/www.off...48161d9cc.jpeg
Rear motor mount clearance to slide closer to the tunnel
https://cimg8.ibsrv.net/gimg/www.off...5f638e1b9.jpeg
After cutting a bit out the mount out I wanted to fill some of it back in to regain strength
https://cimg2.ibsrv.net/gimg/www.off...536a2dd03.jpeg
Taking an inch and three quarters out to move inboard
https://cimg1.ibsrv.net/gimg/www.off...740f0089a.jpeg
Clearance for tunnel on the front motor mounts
https://cimg3.ibsrv.net/gimg/www.off...b675c103e.jpeg
New piece tacked in
https://cimg0.ibsrv.net/gimg/www.off...95401c971.jpeg
Fully welded (1/16Ē dual shield)
https://cimg4.ibsrv.net/gimg/www.off...d318d96df.jpeg
Sanded flat
https://cimg0.ibsrv.net/gimg/www.off...cad323165.jpeg
And the clearance cut out to move over
https://cimg7.ibsrv.net/gimg/www.off...6afce2513.jpeg
Built a jig to ensure the mounts were true with eachother and still maintained a 9Ē offset in height difference
https://cimg6.ibsrv.net/gimg/www.off...028017dae.jpeg
Both mounts setting on jig
https://cimg9.ibsrv.net/gimg/www.off...81378c665.jpeg
One side of mounts done!
Cash Bar 02-25-2019 11:06 PM
Wow. More than a project I think. It's a mission
Rossman 02-26-2019 09:27 AM
There is a little incentive to go a few MPH faster than a 40í skater around town :)
Rossman 02-26-2019 09:32 AM
I wanted to fill in the stringers that had been cut down and kind of just went off the deep in with sanding in the bilge for paint and what not. The boat came with a single hatch that opens front to rear. I am thinking about either going back to the barn doors that open to the outside of the boat or making two skinnier hatches that open toward the middle of the boat. Either way I would like to have a hatch in the center for fenders and ropes... possibly a cooler.
https://cimg0.ibsrv.net/gimg/www.off...55794ca05.jpeg
Mounts on the motor
https://cimg6.ibsrv.net/gimg/www.off...727727f46.jpeg
https://cimg3.ibsrv.net/gimg/www.off...9aee5e010.jpeg
The begining of a long journey
https://cimg3.ibsrv.net/gimg/www.off...4d7672224.jpeg
https://cimg5.ibsrv.net/gimg/www.off...c80fa5222.jpeg
Started sanding and figured it was time to split the barn in half with some plastic. Iíve got a few other toys nestled in there and didnít want to have to detail them after sanding and now I only have to heat half of the barn!
https://cimg3.ibsrv.net/gimg/www.off...a872901ac.jpeg
https://cimg2.ibsrv.net/gimg/www.off...c9e54f858.jpeg
https://cimg2.ibsrv.net/gimg/www.off...e79a01e0e.jpeg
https://cimg0.ibsrv.net/gimg/www.off...dca77e5a3.jpeg
https://cimg7.ibsrv.net/gimg/www.off...115e55275.jpeg
https://cimg5.ibsrv.net/gimg/www.off...060c537ac.jpeg
https://cimg4.ibsrv.net/gimg/www.off...ec8021dbc.jpeg
https://cimg9.ibsrv.net/gimg/www.off...2e6ec6b89.jpeg
https://cimg4.ibsrv.net/gimg/www.off...fb21b2e2b.jpeg
https://cimg8.ibsrv.net/gimg/www.off...77b0e9dc6.jpeg
Let there be light!
https://cimg9.ibsrv.net/gimg/www.off...ae89d18f9.jpeg
Before the overhead lights
https://cimg1.ibsrv.net/gimg/www.off...3b43d3f38.jpeg
After. Much much better
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
