454 questions
Looking a running twin turbos on my 454s in my cat. Pushing kaama surface drives. My plan is to run a blow thru twin turbo set up. My question is does water come out of the exhaust ports on the block? If thats a no does water enter the manifold or is there a pump inline on the exhaust after the riser? I guess my question is i dont want any water entering the turbines on the turbo where it should be all air. Thanks in advance
No water does not enter the manifold VIA the exhaust ports on the head. Typically the water enters the manifolds from hoses coming off the thermostat housing some people even run dry exhaust where the water never mixes with the exhaust gases. The insides of "wet" manifolds are jacketed and the water does not mix with the exhaust gases until it is in the tail or down pipe leaving the boat. To run turbos you will likely require custom manifolds to make it work I don't believe its possible to just add them to a standard style exhaust.
Fireckn ive been reading a bunch online but nobody really has done any turbo set ups on boats except for jet boats. Most of them are car engines. If its a blow thru use the gil marine manifolds i have now, Weld a turbo flange on them, and my plans are to run an intercooler. Help with cooling.
Originally Posted by 31copelandcat
(Post 4708405)
There have been marine 454 turbo setups for years, they are just not popular. With enough digging you should find info, parts, setups etc... Some fountains ran them back in the day.
https://www.offshoreonly.com/forums/...echnology.html https://www.offshoreonly.com/forums/...rbo-setup.html |
Complete twin turbo set up with manifolds $700 on West Palm Beach Craigslist. This might help you get started. Good luck.
| All times are GMT -5. The time now is 12:54 AM. |
