EFI- who’s running o2 sensors? >
EFI- who?s running o2 sensors?
Old 09-08-2020 | 07:48 PM
I found this angles heat sink that helps keep the moisture away from the sensor. I did a back to back test with and without it with no effect on the AFRs.
Baja Rooster is offline
Old 03-22-2025 | 07:17 PM
Default sniper
I am putting a couple MerCruiser 250 superchargers with coolers on some 454/330 horse motors that I’m rebuilding. Would like to use sniper EFI and an O2 sensor if possible. I want to leave the stock exhaust on it though, I am limiting the horsepower because I have bravo ones. Anybody done this?
1983377 is offline
Old 03-22-2025 | 07:36 PM
Rookie's Avatar
Anybody done this?
You should be limiting the horsepower because you have 330's with cast pistons and cast crank.
And I don't believe anyone on this forum would recommend this.
Rookie is offline
Old 03-23-2025 | 06:58 AM
SB
There are several (3-4 ? )companies that make plates for adding O2 sensors in between the manifold and riser.
Google search oxygen sensor plates for Mercruiser marine engines.
SB is offline
Old 03-23-2025 | 10:25 AM
I have used wide band o2 for years with no problems, affordable fuel injection make o2 plates for a lot of marine exhausts, they even made me some custom one for my new water manifolds, I did use the old Holley commander 950 on a Holley 250 blower with twin 900 cfm tbi, they are not self tuning but was fairly easy to tune with wide band o2. Not sure I would trust the self tuning with a sniper, also with the ecu in the throttle body they are subject to a lot of heat and vibration, maybe others have more experience with the sniper system, I still use the commander 950 it has proved it self with bullet prove reliability, unfortunately Holley no longer supports it., the sniper 2 is better
496blower is offline
Old 04-03-2025 | 04:45 PM
Steve H's Avatar
artselectricinc.com
I have lots of dead o2 sensors over the years. Zero issues for over 100 hours after I installed bung extender found here:
https://www.innovatemotorsports.com/...6D2Jpm2tnQZ2SR
It must be clocked correctly to be effective.
Running open loop is not ideal in my opinion.
Steve
Steve H is offline
