1988 Chris craft stinger 260
#91
this boat is bringin' sexy back!
#94
The following 7 users liked this post by JaniH:
1800thomas (09-14-2022), Gimme Fuel (09-12-2022), JohanSweden (09-12-2022), ksalmine (09-11-2022), rak rua (09-11-2022), resurrected (09-12-2022), Twin O/B Sonic (09-11-2022)
JaniH (09-12-2022)
#96
Few problems to solve, only took it to 5000rpm trim full down 60mph, 24" bravo prop, 18% slip. Cruising at 3000rpm 25% slip @ trim full down. Next test with hydromotive p5x 24"
#97
Overal boat handeled great, no prpoising at any speed/trim angle. Too much slip! No signs of stinger hop, but guess it will come when i find som grip.
#98
Today 64mph with hydro p5x 24". trim up does not work under load. seems that my hoses are connected wrong at the trim pump.
#99
Got my trim working, just a little tap trim up and hull is freeing up. More the speed increases the more i can trim up without cavitation. No WOT test yet.
Hydromotive p5x 24"
2700rpm=30mph=27% slip
3000rpm=33mph=27% slip
3500rpm=42mph=21% slip
4500rpm=60mph=12% slip
Boat planes nicely but trim has little to no effect under 4000rpm speeds, still it does not feel bow heavy, and rides like its on rails. Also have a bravo 24" blade, but those slip numbers make me think it is not even worth to try. Have not tried WOT speed yet, but i have feeling that the slip would lower than the 12% @4500rpm. Considering to try 1/2" drive spacer. What is the typical slip @ cruising speeds in these hulls, propshaft 4.7" below?
Hydromotive p5x 24"
