Monza MX 24
Hi everyone,I am newbie to this forum and I am a new proud owner of a 1982 Monza MX 24 with a big block Chevy I believe is a 427 with a TRS out drive .The boat is in excelent condition all round except was not stored properly and the cylinders have rust .I have a newer rebuilt 454 that I was going to put in and my question is the engine in the boat has no circulating water pump.I have never seen this before and assume it is to save HP ,the 454 has a water pump on the engine as well as a sea pump.should I stay with the original setup or do I use the 2 pump setup ?
are you located in connecticut. my uncles friend use to own a 24 in the 80s called heats on and later the name was changed to redline and the new owner put 427 in it. as for the 454, is it complete with the thermostat housing on it. if not i would use the set up from the 427.
Originally Posted by seaman
(Post 4759907)
Do you have pictures of your 24? I'm trying to find out what I have. By my hull # mine was built by sunshine boats miami florida in 88.
