Originally Posted by nocigarette
(Post 4853666)
last time i had a set built they were weldled poorly and didnt fit as good as i like. For the money they charge they should fly someone out and measure them.
The OP solved it an even better way! https://cimg4.ibsrv.net/gimg/www.off...5def17fb69.jpg |
Nice fab on the pipes!.......if your capable, more boaters in this economy should go the way of Bad Chad! where dids you get the SSM 3 decals? ..or were they there previously?
(Post 4853676)
I heard that, so instead we mocked like this and sent it to them (glued and screwed). Made them send the mockups back with the pipes so we knew they didn't screw up. More work but like you said if not, no way do you know you will get what you want.
Originally Posted by scippy
(Post 4853687)
(Post 4853690)
the decals were made by another friend of mine. he does them on any color.
(Post 4853692)
No pressure, but Could I buy the same as yours fo my SSM 3 drives?
Mike 734 363 0410 |
old dash to new. took a lot of hours ansd aluminum shavings but the new gauges,steering,switches are coming to a end.
https://cimg8.ibsrv.net/gimg/www.off...e5621f9b20.jpg https://cimg2.ibsrv.net/gimg/www.off...624bc5064d.jpg |
Dont bust my balls they are not tight yet. some of them are not indexed yet. Waiting for help lol
What cylinder heads are you using on your new motors. Those heads in your mock up have standard Chevy exhaust port heights, hopefully your heads on your new motors don’t have raised exhaust ports .
Originally Posted by TomFTM
(Post 4854596)
| All times are GMT -5. The time now is 07:14 PM. |
