Originally Posted by RBeyer
(Post 4789679)
Second time out with Imco"s and -2 shorties. I don't love the cavitation when getting on plane, can live with it though. Picked up 3 MPH and 300 to 400 RPM with less trim with a full tank. Still tweaking and adjusting but results are not bad.
Prop slip is 17.7 so thinking maybe a 5 blade should help slippage and cavitation planing. |
With a full tank and 4 adults 94, that was typically 91 last year. Better with two people and 1/2 tank. Best of 94 last year.
ordered my imco shorties. man writing that check hurt.
what props did you run with? |
Originally Posted by SABER28
(Post 4790965)
did you try to run your three blades on the imco lowers?
(Post 4794430)
i almost could not find props. no one has the bravo one four blades. got some made with allot of begging , hill marine signatures. thought i was running those 3 blades at idle for the summer. lol
tested mine, allot of cavitation. gets on plane but i'm doing a burnout for about ten seconds till they hook up. should i try five blades?
(Post 4796020)
guy that built my drives calls five blades drive breakers.
thats what i found out, soon as they slip i give it more throttle and back off as the nose drops. |
| All times are GMT -5. The time now is 10:55 AM. |
