-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Prop Size on 30' with T330 454's (https://www.offshoreonly.com/forums/scarab/10722-prop-size-30-t330-454s.html)
FireCapt911 01-26-2002 09:39 PM
I bought a 1981 Scarab 30' with T330 hp 454's without props. I need to know which size props I need to get going with.
Thanks for your help.
Paul
MikeScarab28XLT 01-27-2002 02:43 PM
Welcome FireCapt911,
a littel help can be this i hope !
http://www.geocities.com/mickey1692000/MemBoats.html
www.propbase.com
I use 25 Mirage on a 28XLT Scarab with twin 454 Mags (365HP) boat = 7000lbs
Only my tip for you is a 23" Mirage.
Mit freundlichem Gruß
Michael F GERMANY
Scarab3DMC 01-28-2002 06:50 AM
I agree.. but I'd go 23 pitch Mirage-Plusor 22 pitch HYdromotive 4 blade.. look in prop sectionfor good deals..Dave
Wally 01-28-2002 11:11 AM
yes 23 is the way to go for that one :D
FireCapt911 01-31-2002 09:37 PM
Thanks, Guys
I'll start with the 23...
chuckgo6 08-09-2005 03:56 AM
Re: Prop Size on 30' with T330 454's
I'm don't know prop's that well but I'm runing a Mirage 1 26" pitch 4 blade's on my twin 496's(550hp each motor) 1987 38' scarab and it moves the boat very well.
Good Luck! Chuck...............
Wally 08-09-2005 08:35 AM
Chuck you have the power to spin those props though....330hp dont do to well trying to move a heavy boat around with tall props. My 30' scarab had the 23's witht he stock 330's. Just for kicks i tried a set of 25's a friend had and the engines couldnt spin past 4600 no matter what i did....they just dont have the power for anything bigger.
chuckgo6 08-10-2005 03:34 AM
Wally,
Like I said I don't know that much on prop's? I guess you need to try different pitches in the props if you are able to borrow any? instead of buying exspensive ones and find out they don't work.My Scarab is pretty light(9,100lbs.KV hull)) and the guy I bought it from really knows his boats so I'm sure I have the rite prop's for mine?
Chuck..........
Westcoast 08-17-2005 04:28 AM
i have a 80 flat deck 30 with same power and merctrans. Better to stick with the cleavers than a mirage if you want those trannys to hold up...I am running 24p and have swapped a friend's 23 on the boat and have similer results with both(1/4 inch dia. smaller with the 24's) I have lots of answers to your 30 questions ....just completed a complete refit/rebuild on mine...
eddie
Rookie 08-24-2005 09:42 AM
I agree,
I have an '86, 30 footer with twin 425's TRS and run 25 mirages. I have a friend with a '88, 30 footer with twin 330's bravo running 23 mirage +, he can't spin the 25's.
