fast22 what props are you running on that Scarab and drives?
It's a standard bravo on a 12" imco box wich coincidentally is at Precision Marine being rebuilt right now:( I'm running a b1 26 that has been labbed and worked a little bit, best Ive seen so far is 70mph but i had alot of problems with the drive, hoping for low to mid 70's when I get it back.
Originally Posted by fast22
(Post 2306617)
Mark do your blower set up? |
The motor was actually built by a shop in TX, but the computer was sent to Mark for the mapping.
3 Attachment(s)
SKATER NATION !!!!!:ernaehrung004:
2 Attachment(s)
newbies..565 cuin....650 ftlbs..:cool-smiley-011::ernaehrung004:
Originally Posted by Strip Poker 388
(Post 2305794)
then carried away:rolleyes:
fast22 you should have no problem. I have 625 HP turning a stock B1 26p at 5050 and around 72-73 with a half tank of gas and my wife on board. Best I have seen is 75.2 GPS but it doesn't stay there just bounces up there on the gps. I do not like the B1 but haven't had a chance to try anything else since getting my motor back in the boat in late July :( I would like to try a 27P Mirage or M+ just have to find one to try in my area. Good luck with your set up.
2 Attachment(s)
Here is a pic of the box, hopefully the new lower without the cone and that nasty skeg will help a little too. Scarab3DMC motors look good!!
1 Attachment(s)
Ive seen 65mph on the 210 fwy. Getting about 145 hp at the crank.I think I can probably pick up a few ponies with a K&N.
| All times are GMT -5. The time now is 03:11 AM. |
