-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Whats in your garage? (https://www.offshoreonly.com/forums/scarab/177446-whats-your-garage.html)
Sulfur1 01-14-2008 02:59 PM
Hi all,
I'm buying a house with a garage:evilb: that I plan on using to store and do maint. and general up keep on the Scarab. what comes to mind to you when you want to set up a garage just for the boat? The space I'll have will be roughly 35' wide by 40' long. Here in Baltimore County the height restriction is 15' high for garages, and I believe that is to the exterior peak of the roof. Unless I go with a flat roof and I can get a few feet more of clearance from that. Any way what tools and equipment would you use to set up a nice shop? I already have the basics down to start with, power and water. All thoughts and comments will be considered.
Thanks again,
Sulfur 1
JPD Motorsports 01-14-2008 03:13 PM
outdrive jack, a table/bench for teardown only, a table/bench for assembly only, 55 gallon drum for old oil, air and electric overhead so that if you are standing in boat you can plug in a vac or air line instead of draped over the side, some cabinets, a phone, internet with a comp, incase you need to look up and search stuff parts hunt, a roll around tool tray for moving what nots around the boat, large hot water heater and a toilet, parts washer and a lot of good light.
Sulfur1 01-14-2008 07:35 PM
JPD,
A large hot water heater? Please explain.
Thanks,
Sulfur1
dj_merk_e 01-14-2008 08:24 PM
you need
1 Attachment(s)
Aair compressor with all the air tools for sure....and if possable a i beam a crossed the ceiling to pull motors....
Sulfur1 01-14-2008 08:45 PM
dj,
Thanks for the info. not to sure if I'll be pulling motors, but I'll keep it in mind...just in case.
Thanks,
Sulfur1
satisfactionII 01-14-2008 09:04 PM
This
1 Attachment(s)
:cool-smiley-011:
Sulfur1 01-15-2008 10:17 AM
Thanks marylandmark, I'll look into that. Ok, so why does everyone hit on the air compressor item? Someone, please edumakate me.
Thanks,
Sulfur1
RunninHotRacing163.1 01-15-2008 11:22 AM
Originally Posted by marylandmark (Post 2407092)
The three maiin reasons why a growing number of do-it-yourselfers are pulling the plug on the electric tools in exchange for air tools.
1. Power to Weight
One of the biggest advantages that air tools have over electric-powerd tools is that thy do not require their own motos. Instead, a single air compressor motor converts electrical energy into kinetic energy.
Air tools deliver more torgue and higher revolutions per minute than an electric-powered tool, enabling uses to accomplish their tasks more quickly and effectively.
The power-to-weight ratio is much higher, as a result, air tools are smaller, lighter, and easier to handle. You can store ten air tools in the same spance as three to four electric-power tools.
2. Value
Accordingly to homeowner's who switched to pneumatic tools, there is an intial air compressor investment, but the inexpensive air tools and accessories quickly offset the added expense.
When you buy an air compressor, you're getting one powerful motor instead of a dozen small little motors that burn out. Air tools are considerably less expensive and last a lot longer then electric-powerd tools.
3. Versatility
Whether you're inflating tires and backyard pools or building elaborate decks, air tools are and easy-to interchange alternative to electric-powered tools.
Homeowners use a variety of air tools for different tasks, including impact wrench, spray gun, finish nailer, angle nailer and ratchet wrench. Homeowners really like the simplicity of having one power source for all these tools.
Outlets as well- put electrical outlets every so often- alternating with the air compressor outlets so the cords don't get tangled.
Holy CHIT MM , you wrote all that ???? you've been following CS around too much LMAO :cool-smiley-011:
RunninHotRacing163.1 01-15-2008 11:33 AM
Originally Posted by marylandmark (Post 2407131)
You kidding? Cut and paste bro- I am not that well versed! :D I put it in leaning letters to show the cut and paste..
I did however draw the pretty picture above!
Added bonus to compressor in the bathroom besides noise reduction is when you "blow it up" the compressor sucks the air out of the bathroom and you can put the nozzle thing on the end of the hose and squirt it down in the bilge while your buddy is working in there to "share"! :p
NOW THATS GOOD !!!!! , and the large Hot water tank is for the jacuzzi tub for the neighbors daughter you want to take boating this summer LMAO:grinser010:
JPD Motorsports 01-15-2008 01:54 PM
large hot water heater, for if you wash the boat you can use hot water to soap it with and cool to wash down with the small ones that are usually in a garge run out and you have to wait for it to heat up again. Air compressor is nice for impact guns for trailer maintnace change tires a blow nozzle to get into the crevasises(sp) in the boat to clean them out, run a bunck of different tools off of. Deffenately mount the compressor either in its own shed outside, or in a sealed up room heavilly insulated for the noise will get old when it cycles.
Sulfur1 01-15-2008 07:24 PM
Ok, I got it. So, what size/brand air compressor do you guys suggest? And air tools any favorites?
Sulfur1
Sulfur1 01-20-2008 10:13 PM
Ok, now I have another question for everyone. The garage that I'm expanding also has a carport off to one side. I want to extend the garage and the carport to the fence line at the bottom of the driveway and enclose the carport. Question is: The surface that I am extending over is blacktop. Do I need to remove it and repave with concrete? The garage portion is already concrete although it needs a skim coat. Or can I go over the concrete in the garage with blacktop and call it a day? Please any and all suggestions are more than welcome. OK, decided to check something and I need to clarify. The area where the structure of the garage that contacts the ground would be concrete. Best I could describe it as if you looked at a deepthroat "C" clamp, the concrete would be the "C" and the blacktop would be filling in the middle, where my truck and boat would sit. Can I do it that way? If your as confused as I am, please PM me and I'll try to describe it a little better.
Thanks again,
Sulfur1
Mike J 01-21-2008 10:38 AM
I have a 30'x40' ft boat shed with a 40'trailer along side for all
the extras, One thing I did was build a overhead storage area
at the back end of the shed that I use for storage of "stuff"
like seats and hatches I have 3 Scarabs inside a 30',26' and
my 16ft Jet Sprint.
The overhead and the Flooring are made from Militery DRMO
C.B. stuff and work very well there should be a lot of that in
your area "CHEAP". Mike J.
dukenrock 01-21-2008 10:48 AM
1 Attachment(s)
Nothing in this one yet, but I have the plans finally completed. Hopefully will break ground early spring.
Sydwayz 01-21-2008 01:26 PM
Put a "bonus room" on top of the garage for an office or small home gym, and build that sucker as high as you want.
You will need a minimum of 12' ceiling height to do anything on the boat. You can't even open an engine hatch very far under a 10' ceiling. You need 2' of clearance above a typical garage door, (10' high door needs 12' high ceiling). If you were to go with a 12' ceiling, and only have 3 more feet before you hit your exterior height restriction, there will no way you will be able to engineer the truss/slope/roof for snow load; in a residential type building.
More notes/info here:
http://www.offshoreonly.com/forums/s...d.php?t=170427
Sulfur1 01-25-2008 09:27 AM
Hi all,
I would like to thank everyone for your input. I have another question. Why can't I enclose the exsisting blacktop pavement and use it as my extended garage floor? It's in great shape and the foundation that the garage is built on is concrete (around the perimeter of the blacktop). For the winter season I've decided to go with either a wood stove or 2 wall mounted propane heaters fed by 1-2 124 lb. propane tank(s).
Thanks again,
Sulfur1
nova26 02-02-2008 02:31 PM
Brass pole in the corner???
Sulfur1 02-05-2008 06:28 PM
nova26,
I already have one of those in the basement of the house.
Sulfur1 02-05-2008 08:48 PM
Ok everyone I appreciate all the input that I have rec'vd on the forum about my latest money pit, the garage. I have one last question and I'll leave you all alone...LOL. the garage footprint has grown from approx. 28 X 28 to 30 X 45 with a max. peak height of 15 ft. Were talking an approx. sq. footage of 1350 sq. ft. more if you count in the height to the peak. Anyway, my latest headache is how to heat this thing during the cold months when I'm working on the boat. I was thinking of two 100 lb. propane bottles with two 1,000 BTU heaters at each end of the garage, and a ceiling fan in the middle to mix it all up...LOL. I do have electricity and natural gas to the house which is about 60'-70' away. But I'd like to keep the garage off of the home heating and cooling bills. So, do you all think it is worth it? Is there something else available that I'm missing? Anyone out there that heats their garage area with propane? Do you like it? Pro's con's? Thanks again for the input.
Sulfur1
Sulfur1 02-29-2008 08:13 PM
Hi all,
Yup, I'm gonna hit this thing again. If you had a choice between a pole building and a steel truss building, which would you preferr? Both buildings are 30 X 45 clear span (no support poles in the middle). The steel truss building is about 4k more in price. Thanks for your comments.
