-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   To power up or not to power up? (https://www.offshoreonly.com/forums/scarab/184471-power-up-not-power-up.html)
zul36 04-14-2008 10:57 AM
Hey guys-I have a 2002 29' Scarab. I've had it since new and it's powered with a 496 HO. The boat gives a great ride and is truly a Cadilac on water, but I've never been happy with the lack of power. Getting the boat to plane with only 425 HP is a pain......I think the boat need about 600 to 750 hp.
I research several engine manufactures and it appears that Raylar probably offers the best and most affordable up grade. Thier 600 hp upgrade gives me strenght for a supr charger should I need additional power.
Can anybody out there give me a reason why I should or shouldn't bother?.....Is it worth the effort or will I be disappointed?...Should I just go for a new boat?
Thanks,
jc
Run_em_hard 04-14-2008 11:24 AM
If getting on plane is your only problem, that could possibly be fixed with a different prop. Also do you have tabs?
zul36 04-14-2008 12:55 PM
Yes I have tabs.
zul36 04-14-2008 01:26 PM
Also I have changed to a 4 blade 22 inch prop, but it affects my top end. I use my 4 blade 24 to have better top end, but out of the hole becomes a problem.
Perlmudder 04-14-2008 01:51 PM
from what I have heard everyone who uses the raylar kits seems to love them, good luck. they do say though that it is cheaper to just buy a faster boat then to make your boat faster
zul36 04-14-2008 02:17 PM
I'm actually more interested in knowing how the boat handels the extra power, with less weight....Does it become squirly and uncontrolable?
fast22 04-14-2008 06:21 PM
I have about 630hp in mine, with a 26p bravo it runs right at 70-ish @5200rpm and a normal load. I have a standard length bravo with a ext-box and external steering, there is nothing squirlly about it, runs like it on rails:cool-smiley-011: They are kind of a heavy boat for a single and they love extra power, just watch that bravo I'm on my second one:D
zul36 04-15-2008 12:20 AM
Thanks, that's the information I was looking for. I'm hoping my drive can handle the extra power. I presently have an Imco drive equivalent to the XR drive with a 2" shortie lower unit. I wonder how my boat will do with the shorter lower unit???...Faster or slower
fast22 04-15-2008 06:49 AM
From what I understand the scrarabs like the shorter lowers, thats the next thing on my list. Did you pick up any speed when you added it? What kind of speeds are you seeing with your setup?
Scott
zul36 04-15-2008 10:07 AM
I've only seen a maximum of 57 on my GPS at Lake Havasu in 100 degree weather. I have kissed 59 on a cold day in Northern California.
When I first bought my boat I was going to whipple, but because the 496HO was fairly new in 2002 I didn't want to take any chances.
Now I'll just pop in the Raylar 600, that should have enough strenght for an additional whipple if needed.
