-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   New power ready to go in (https://www.offshoreonly.com/forums/scarab/188928-new-power-ready-go.html)
scottie150 06-18-2008 11:59 PM
Originally Posted by jaxx 30 (Post 2594178)
Speaking of the SCARAB PICS, are there only 5 to 6 scarabs on here? Of course mine is the "classic".
Are we feeling a wee bit inferior today? :D
jaxx 30 06-19-2008 06:28 PM
Inferior? Maybe. My 77' Scarab is the oldest here, I think. My drives were made in 1976. So I'll go with "classic".
Rookie 06-19-2008 11:17 PM
Originally Posted by jaxx 30 (Post 2594569)
Looks like your stuff is already matched up, but I was curious as to why the 750's on what seem to be tricked BBC's.
Thats a real simple answer....thats what I had. Also Jim and others said that I would be losing a little on the low end and gaining higher on the top.
I started out wanting to build some engines that would put out 550HP, but as the build went on I decided to put the goodies inside it so the final limiting factor restricting my HP would be the carb.(easiest variable to change) I was going to try a friends 850 but after seeing that I was well over my build goals I decided to just stick with my 750's. I ran the engine on the dyno while hooked up to my hand held Innovate LM-1 AFR meter and wrote the readings down. If down the road I decide that I need a little more power I will then try some 850's. I think I might be as fast as I want to go, but only time will tell.
jaxx 30 06-21-2008 05:04 PM
I once ran a 468 in a 69' camaro. I had a .680 lift roller cam and rect heads. I ran a holly race 830 carb that had 4 corner idle and annular boosters. The carb was a good deal at the time at $380 from summit. I was thinking that carb would be sometyhing to look at when you are ready. It gave me really good throttle response down low and plenty up top. I had a 7200 shift point with my setup (9.8-10.2 comp.). But I hear you when you say I ran it cause I had it! Good call on putting the good inside before outside.
