Install a shower at 38 scarab 377
How easy is to install a shower at a 377 scarab?
Now they have 2 small sinks and one port-i-potti. No shower. I want to istall one externall shower to the back, one inside the WC and a mechanical satination device Any idea? Thanks |
thought about this myself a few times. it would have to be in the center of the cabin at the very back to take advantage of the height. - good luck - jeff
You could put one outside at the swim step.T into the sink feed line then run hose to the transom.above the transom were there is only glass.install a threw hull that you could attatch a hose and a shower head/or sprayer.the threw hull will need a cap for when not in use.with the pressure pump on and the sink off,all the pressure will go to the back.This is how I did it and it worked great.make sure you get a threw hull that has a screw type cap to close it off
| All times are GMT -5. The time now is 01:15 AM. |
