-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Drive spacer question for 29 scarab single (https://www.offshoreonly.com/forums/scarab/200529-drive-spacer-question-29-scarab-single.html)
shotime113 12-22-2008 09:41 PM
I would like to know if anybody with high horsepower use's a drive spacer ? And if so what size with a 4 blade prop ?
Jeff P31 12-30-2008 04:47 PM
Can not see needing spacers on a single . just my .02
scarabman 12-30-2008 04:59 PM
Agreed. If anything I would be thinking shorter!
shotime113 12-31-2008 12:46 AM
I have 900 hp. And as the tourque come on the prop cavatates I am trying to spend a 30 pitch bravo 4 blade.
Ant thought any help would be great Thanks....
Jeff P31 01-01-2009 02:10 PM
I have the same problem getting on plane but once it is up and running it seems to be fine . Running 1 inch shorty 30 props & 750 hp each . I to would like to fix this problem .
shotime113 01-01-2009 06:15 PM
Thanks Jeff , But I only have a single. And the boat runs very well with some of my fat friends in the back seat. So would that mean that I need a spacer in there? And a bravo 1 for now. imco xr drive next month.
THOUGHTS ????
hullofjustis 01-10-2009 03:22 PM
I had a 29 single engine with 820hp with a 1 inch shorty and had no problem getting on plane with a 26 bravo one spinning 5800 rpm what are turning rpm wise?
shotime113 01-10-2009 11:51 PM
I have only spun the motor up to 5200 and the prop slipage is horable. What was your prop slipage ? And was that a 3 or 4 blade prop ? And thank you for responding:cool :
DareDevil 01-10-2009 11:59 PM
I don't have a scarab and i don't have a bravo,,,,,,but from what i know u need to go up not deeper in the water with a single if slip is to high.
Whats the RPM and MPH your runnig and what gear ratio ?
shotime113 01-11-2009 01:09 AM
4200 rpms @ 56 mph with a 30 pitch prop. the propellar lifts the rear of the boat when hose power is being produced.
