-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   need prop advice for 29 (https://www.offshoreonly.com/forums/scarab/211051-need-prop-advice-29-a.html)
96scarab29 06-15-2009 10:29 PM
I have a 1996 29 single 502/415 with a bravo1 drive, looking for some advice on a prop( 3 or 4 blade ) and a good pitch. Also any estimates on speed with a certain prop would be awesome. Thanks in advance and happy boating, its starting to get good here at lake st clair, michigan:evilb:
2DXTREEM 07-11-2009 12:13 PM
I ran a bravo1 24 pitch on mine, ran 66 b4 i re-powered.
96scarab29 07-13-2009 05:06 PM
66 huh, thats better than I was thinking. do you remember if it was a 3 or 4 blade? anyone else have any advice? I'm hopefully going to be in the water this weekend, thanks in advance
2DXTREEM 07-14-2009 09:41 AM
Yea, actually ran 68 at its best, standard speedo though. The only thing done to the motor was emi thunder exhaust and the vortech power-up kit. Tried a 26 4 blade but only spun it 4500. So the 24 was a good set-up.
SCARAB2925 08-12-2009 09:00 PM
I have the same boat and i am running a hydromotive 4 blade 22 pitch spins 5000rpms wot and tops out at 64 with a lite chop on the water. Also a michigan boater to!!!
huge 08-21-2009 09:27 PM
I have a 95 with a single HP500.
Bought it in '05 and the previous owner had a 23 mirage which he claimed hit 5700 rpm and ???mph.
I did not even try the 23 and put a 25 labbed mirage on and ran about 66 on GPS.
In '06 I rebuilt and installed a ProCharger, which dyno'ed at 713HP. I ran a 28 Bravo at 5200 rpm and could always hit 78 mph and twice hit 79.6 (damned if I could hit 80!)
Since then took the ProCharger off and now run the stock HP500 (which btw made 517 Hp on the dyno back in 2006).
I now run a 24 labbed Bravo and hit 66-67 on GPS and about 5400 RPM
Mirage30 08-22-2009 11:14 AM
unbelivable,we run with 29 scarab from 2000,502 MPI,23 Mirage Plus,1.65 Gear ratio 5100 Rpm 56 Mls!!:eek:
fast22 08-22-2009 01:31 PM
I would like to know how ya'll are getting these numbers with stock 502's. I have a whippled 509" making 630hp@5300rpms and I'm getting 72 with a light load(two people and 1 Ice chest). My buddy I boat with every weekend has a 96' with a carbed 540" making about 600hp and he gets 68mph in pretty much any conitions. He had a stock 502 when he bought it and was nowhere near 66. Did ya'll remove the hook in the hull to see these numbers?
Scott
