-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   X dimension on a 33? (https://www.offshoreonly.com/forums/scarab/216430-x-dimension-33-a.html)
DirtyMoney 09-08-2009 07:08 AM
Where are you? I am still trying to find my missing speed.
scarabman 09-09-2009 06:49 AM
Is this a rhetorical question?
DirtyMoney 09-09-2009 01:28 PM
I am 6" below bottom of running surface in front of prop.
The best I can get is 78.5mph with 17% slip.
scarabman 09-09-2009 05:34 PM
What props and what RPM? What is your HP?
DirtyMoney 09-09-2009 10:59 PM
4 blade 30's
5000rpm
not sure on hp, running a pair of 540's hp500 cam, hp 500 carb, pro top line heads
scarabman 09-10-2009 03:42 AM
As a baseline, all 33s had the same x dimension. My previous 33 with HP500 carb motors ran a best of 82.3 with labbed 28 Bravo 4 blades spinning at about 5400. It also ran about the same speed with labbed 30 Bravo 4 blades spinning a little over 5100 rpm as I recall. These were stock motors w/ 470 pshp other than getting rid of the rev limiter.
Without knowing your HP, but based strictly on CIs, I would think you should be able to pull 30s to a little more RPM than than 5000.
Are the props in good shape, blades true and such? Have they been labbed?
What condition is the bottom of the boat in? How much gear and such do you keep on board? Is it possible weight is holding you back?
