-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   scarab (https://www.offshoreonly.com/forums/scarab/217555-scarab.html)
D Harry 09-26-2009 02:13 PM
scarab
I just put a 525 efi on my 22, still dailing it in but she's a hand full. just got a cnc prop from matt of Throttle up but didn't have the chance to try it cause the weather here is awful
Harry
I think is the only one with that power in the world
D Harry 09-26-2009 02:14 PM
scarab 22
Harry
I think is the only one with that power in the world[/QUOTE]
fastscarab22 09-26-2009 05:14 PM
i have a scarab 22 with over 500 hp and i put 1 inch shorty on it and and i put steerting on it and tabs ( never use them but i ride on them) i have no chime walk and i am doing over 80 mph on gps i run a 26 bravo 1 and i have a 25 solas titan hr that i can spin to 5600 rpms with out a problem
D Harry 09-27-2009 11:11 AM
I have trim tabs from dana marine 17" and also a mayfair full hydraulic steering. The prop is a 30 pitch CNC but I still have some slip issues which I have to take care of cause I only saw 81mph at 5200rpms . :mad: but hopefully i will solve them.
Fastscarab, how come you are running a 25???? I use to run that pitch with a 502mpi standard.
Harry
fastscarab22 09-27-2009 12:32 PM
its a solas high rack, witch means my bow is up and i run it at 5600 when i run it at full blast, i run a 26 bravo 1 that has been labbed most off the time and i can run tat at 5300 , not on my rev limiter the sollas blade gets me there faster . but as i said i was lookinf for a 27 , plus i have a 1 inch shorty on it with a nose cone . is your cnc prop a round ear scott
D Harry 09-28-2009 01:57 PM
Scott,
It's not exactly a round ear, but you can't say it's a cleaver shape neither. I tried once a bravo, but it use to run with the bow to high, and as soon as you hit a 1 foot wave it sends straight up in the air looking skywards.
Harry
fastscarab22 09-28-2009 02:47 PM
been there done that, i put the shorty on and i trim just over 1/4 to 1/2 and i cut there the waves iam talking 2 or 3 and can run at full like that and not get killed, with big power that shorty makes a big differnce in the chop if you go tho you tube you can see it run with the old drive ( scarab 22 at speed on west river )
Unitek 09-28-2009 03:45 PM
525 is not enough in that boat. That boat needs 800 hp minimum
fastscarab22 09-28-2009 04:01 PM
It Would Be One Good Ride, As I Said It Would Be One Good Ride, I Think You Might Not Make Another One Hahahahah
D Harry 09-29-2009 11:04 AM
Scott,
with the shortie the handling improved and I also trim from 1/4 to 1/2 like you. Re the 1 foot wave it was just giving you and example cause we don't have rivers here. We will very luck to have a day in the whole summer with 1 footers, or else you have to risk a speeding ticket and give it shot in the harbour :evilb:
Humm, 800 hp that's an idea. hehehe
Harry
fastscarab22 09-29-2009 02:00 PM
harry, isnt it fun beating on the big boys out there, they think you do 60 , then you let it loose and blow by them with you hair on fire, just keep your hand on the trim buttion and keep the throttle down , scott
