-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Scarab III prop Q (https://www.offshoreonly.com/forums/scarab/228042-scarab-iii-prop-q.html)
thermasystems 04-09-2010 03:59 PM
Scarab III prop Q
I posted this in the Prop section.... probably should have just posted it here.
For you guys with Scarab III's. What props are you running with what power?
Andy
Scarab3DMC 04-10-2010 06:45 AM
with stock 502's I ran.. 21-23 Mirage and Mirage plus, then Hydromotive Q-4's 22 pitch , Q-4's have workrd the best, then with the 525 SC motors I stepped up to 27-28" Q-4's , Now with the 565 cuin N/A motors I still spin the Q-4's 27" @ mid to upper 70's .. 1983 Scarab III w/TRS drives
86scarabIII 04-13-2010 08:19 AM
With stock 454 330's I was running 23 mirage plus'. RPM's were 4600 at WOT, top speed a blazing 50 mph.
Before that I ran regular mirage 21's at 5200 rpm. Ran 59 but had some engine problems so I decided to go up in pitch.
rchevelle71 04-13-2010 11:35 AM
Not sure about your boat, but if it turns out you need a 23 mirage, or 21 mirage plus, I have one of each in the garage that I may sell.
