-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Prop Selection for 21ft Scarab 1 (https://www.offshoreonly.com/forums/scarab/232826-prop-selection-21ft-scarab-1-a.html)
kosmo04 06-16-2010 12:47 PM
I tried doing a little searching and found a little bit but I just wanted to make sure before I pulled the trigger on a new prop for the boat. I know that top speed and hole shots are arch enemies when choosing a prop, so I will just have to compromise. I will be skiing off my boat, so the 3 blade will be the better choice for that, but on other days speed will be what I'm going for.
As of right now, I am under the impression that a 4 blade, 22-24 pitch prop is the way to go for hole shots, and a 3 blade with the same pitch for speed. My boat is a 21ft Scarab, with a 302 sb, and RPMS at WOT are right around 3500, which I know is way too low. If I trim up a bit they go up a bit, but not enough. From what I see I should be running about 5000-5500 RPM at WOT. This is my first boat of this type, and have had smaller ski boats in the past, and I am currently not sure of what my current pitch is on the 3 blade that is on there now is. Any suggestions?
johnlx302 06-19-2010 10:35 AM
when mine had a stock 350 mag i ran a 21 p mirage plus took a little bit to get on plane but not bad had a top speed of 54-55 mph gps. it ran aprox 4800rpm w that setup.
cbell 07-12-2010 11:34 PM
I have a Scarab I for sale right now and it runs 58-60 with a 21p Mirage. It will pull 2 slalom skiers and planes quickly but I have 18" tabs on it. The best prop I have ever had on it is a Merc Power2 which is a switch pitch prop. I have one that is 17p-23p, it starts at 17p to get on plane quickly then switches to 23p at a preset RPM.
CBELL
