29 with twin's or single ???????
so what everyone's thought on a late model 1995 to 2002 29 with either a single bigblock 575hp or twin 350 mag motor's, and of course what the top speed of each would be .
question 2. would the 2 350 mpi motor's be more efficient then a single 540 ci. carb,motor ? thank's mike |
Mike,
I have 1996 with a single 509mpi with a 2.3 whipple making about 620hp. I love it, best so far has been 73ish and its not that bad on gas if you stay out of the BOOST! I'm not positive but I believe in stock form the Mags will run 70 and probably be easier on drives. Scott |
Twins.
I like-a da' twins myself. My 26 Nova has twins.
twins over a single by far
I agree on twins. Easier to dock...probably less maintenance than the one "big" motor...and if one has a problem, you can always get back with the other motor. :drink:
I could be wrong, but I'd be surprised if it went 70 with the mags. Might be close (I'm gonna guess 65-67ish) but I dont think it'll run 70. |
One thing I thought about when I bought my 29 were things like routine maintenance. I can get right down next to my engine on both sides and work on it. Also oil changes and the like are easier. A single 29 is defenitly not the fastest boat on the water though!
My 29 stock will run 67 to 68 mph you will not see 70 in a stock twin 29 scarab
I have been the twin route, I prefer a big single. The reason is fuel, maintance, and weight. I have a 29 Fountain 540 700HP and a 27 Baja Boss 509 m3 Procharged 730 hp. I embarrass Large twin engine boats all the time. I have friends here in florida that have 100k boats that struggle to keep up. when these guys gas up its around 1200 for the weekend. I spend around 400.00 Most of the guys only run wot 75-85 mph.
I had a single engine blown 540 putting out 820hp with a 1 inch imco shorty and it ran 85mph and it was very fuel efficient for what it was.
Twins
My old P-29 was just on ebay for around 30K, but reserve not met. When I had the boat it was running 75 all day and 79 on a good day. Has Revolution Marine aluminum exhaust and Black Hawk surface drives. Plus the Kevlar hull is about 900 lbs lighter than a traditional 29. Was a sweet boat for many years, and had a lot of fun suprising big block boats with the mouse motors. The cool thing about the Black Hawks is you can run across 4 footers at WOT with no chine walk thanks to the offshore K-Planes, the narrow beam, and the drives 7 " higher, but still level. Do not have to pull the sticks back as often, since the drives don't go in and out hard like a Bravo or Alpha. If you could pick that boat up for mid 30's you'd be stealing it. It's number 5 out of 29 (Actually only 27 left I think).
| All times are GMT -5. The time now is 08:25 AM. |
