Gauges for 96 Sprint
I am looking to replace the Speedo & Tach on my 96 Sprint. Currently it has the stock Faria gauges. I am measuring them at 4 5/8 inches, does this sound right? I believe Wellcraft put them on their 22 & 26 ft Scarabs as well. They have a black and orange color scheme. Due to the faux molded carbon fiber dash I can't really go larger or smaller in terms of diameter. Any ideas on who makes gauges that will fit? I checked Faria's site and they don't appear to make this size anymore. I'm not really looking to spend a ton, just looking to get rid of the tach that has a cracked housing and bee trapped in it.
They are more than likely 3 3/8" on the speedo and tach and 2 1/8" on the rest. These are the most common sizes of gauge and are measured at the dash cut-out diameter.
Monster gauges are typically 4 5/8" and 2 5/8" cut-outs I think there are some oddball units out there that have 3 3/4" cutouts as well, but these are much less common Try Hardin Marine. They have some really nice inexpensive kits. |
Thanks huge, Just pulled out the Tach and it measures 4 3/8 accross the back, which seems like even more of an oddball. I've already bought a set of 3 3/8 I might try to find some bezel's to fill the gap.
I went through the same thing with my Scarab 22 tach two years ago... Same gauges as on the 19 Sprint...
I called Faria and of coarse they don't make them anymore, just like you found out... but they told me they could repair the tach. I was lucky and got one off a member this the Scarab forum, who was upgrading to Autometer Guages. |
I found some bezels from monster marine with a 3 3/8 ID and a 4 1/2 OD, so the 3 3/8 gauges should end up working out. If anyone needs the stock gauges pm me, the Speedo, trim, voltmeter, water temp, & fuel gauge are all in good working order.
did those bezels ever work out???
im in the process of trying to find replacement gauges for my scarab 22 with no luck on 4 5/8" gauges. mt trim/fuel/ and water temp all busted... cant replace just 3 ya know? pics would be great!! |
| All times are GMT -5. The time now is 08:17 PM. |
