-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   89 Scarab 22 (https://www.offshoreonly.com/forums/scarab/261450-89-scarab-22-a.html)
khubard 08-31-2011 03:24 PM
89 Scarab 22
I have 89 Scarab 22 with a 350 Magnum. Does anyone know the recomdended WOT RPM'S for this boat..I am trying to determine a prop for it.
scarab63 09-01-2011 12:48 PM
I'd try a 21 three blade. Mirage ... mirage +
khubard 09-01-2011 03:10 PM
Yea I talked to a Prop Shop today and they are suggesting the same thing..He said I should get maxium RPM'S, speed, and my hole shot should be alot better.
RivMan 09-02-2011 10:36 AM
I have the same boat, same power.
I run 4400 RPM with a 4 Blade Merc Rev4 21' - 50 MPH GPS
I run 4800 RPM with a 3 Blade Mirage 21' - 54 MPH GPS
The Mirage works much better all around unless I'm loaded with 7 people and coolers.
-Rob
khubard 09-02-2011 11:14 AM
Well that is what I am getting with a laser 24.. Trying to get the RPM's to 4900..
Mopwr 09-14-2011 07:52 AM
I have a 22 Scarab 1994 Alpha 1 Merc drive with a 350 Mag...I have a Laser II 23 p and can pull 55 - 60 at 4500 to 5000 rpm ...with a full tank and two people....
khubard 09-19-2011 02:15 PM
Installed some new exhaust manifolds and I can now get 60 out of the boat at 4500 rpms. Still running the Laser 24p
khubard 09-29-2011 01:44 PM
Ok guys, now i am really confused..I thought I had a laser 24..But after inspecting the prop i realize I have a Laser 21p..I can only get 4500 rpm's at WOT... Need help to get to 5k on the tack
fastscarab22 09-29-2011 05:18 PM
Do you know what a rev limiter is , and tacks lie
cig92 10-02-2011 06:42 PM
recommended wot rpm's should be posted on your valve cover, prob. 4800
