-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Scarab wouldn't start today!! (https://www.offshoreonly.com/forums/scarab/267019-scarab-wouldnt-start-today.html)
airshares 12-10-2011 10:43 PM
Its a 1997 Scarab with 350MPI's
My starboard motor wouldn't fire today. It cranked and cranked but no fire. I want to try replacing the lanyard kill switch and ignition switch first....or other ideas people can suggest?
I did not check to see if it was getting fuel but I did smell fuel from cranking it.
The port motor fired right up.
One thing Im not sure if this is normal but I noticed the kill switch is touchy. I turn the key and the alarm goes off as normal but after I crank it i notice the oil pressure come up as it should but then the voltage goes to zero when i stop cranking it and the alarm is gone.
I have to turn the key back off then back on again to get the alarm and voltage to show.
humpster 12-11-2011 08:57 AM
same thing happened to my 99 and thats what it ended up being was the kill switch was worn everything else worked as it should just wasn't any spark
airshares 12-11-2011 11:47 AM
Kill switches
Do you know which kill switches to order and where to get them from?
cigboat1 12-11-2011 04:33 PM
[url]WWW.Eddiemarine.com,page104 in catalog ph.909 945 2830.....one of the switches on that page will fit your boat!
Good luck ! Jim
Before you buy any new one pull the kill switch cover off the other engine and put it on the motor that will not start / if that will not work switch the whole kill switch over to the other eng.
humpster 12-11-2011 07:14 PM
mine was just loose had to wiggle it to get the motor to run but it did everything yours is doing it happened at the end of the season so i just by passed it til i can get another one my bad!!!
airshares 12-21-2011 01:33 PM
Update:
I figured id let you guys know what the problem was. The fuel pump was bad. Replaced it and the boat runs again!! Amazing what a little fuel will do.
