What is the HP rating for a 1988 454 Mag motor? >
Old 03-05-2012, 01:38 AM
Default What is the HP rating for a 1988 454 Mag motor?
I know that the 1987 454 was rated at 330 hp with the alpha drive but in 1988 when the Bravo 1 came out does anyone know what a 454 mag was rated at? 330 or 365?
Powerquest_Baby!! is offline
Old 03-05-2012, 07:22 AM
454 Mag Bravo was 365 hp
Baja226sport is offline
Old 03-05-2012, 09:09 AM
jeff32's Avatar
jeff32 is offline
Old 03-05-2012, 03:41 PM
Thats what I thought....Forged internals and rectangular port heads. Thanks!
Old 03-16-2012, 03:47 PM
Rob
Strip Poker 388's Avatar
heres a pick of a 1989 365mag and opt sheet for 89 Scarab
Attached Thumbnails What is the HP rating for a 1988 454 Mag motor?-scarab-1989-28f0001-large-.jpg   What is the HP rating for a 1988 454 Mag motor?-scarab-1989-28f0007-medium-.jpeg
Strip Poker 388 is offline
Old 03-16-2012, 05:44 PM
So, it looks like in 1989 you could get a 7.4 litre 330 hp big block or a 454 mag which should be 365 hp. Your brochure doesnt address outdrives but I assume everything was coming with a bravo at that time.
I only ask this question because I have a 1988 Wellcraft Spyder with a 454 mag and a bravo 1. There is another user on OSO with the exact same boat and motor (I havent seen it but thats what he says) but when he tore his engine down he said the heads were the peanut heads which would mean 330 hp and non forged internals.
What Im trying to determine is what my RPM operating range is. Obviously the 330 hp is 4200-4600 and the mag is 4600-5000 at wot.
Here is a pic of my motor:
Old 03-16-2012, 06:01 PM
if you have the bravo drive i think it is 365 if you have the alpha it is probably around 330 just my thoughts
mach1magnum is offline
Old 03-16-2012, 06:23 PM
Its definitely a Bravo 1 outdrive...Ok, sounds like I do have the 365 hp...Thanks!
Old 03-16-2012, 07:18 PM
Rob
Summer 1989 When I started shoping the used 1988 28 Scarabs most had the 330's .I started looking at new 89's and most of them had the 365's.Mine was built in july 1989.I bought it new as a left over in Feb 1990.The max it turned stock was 5k on a good day.around 62mph .The factory test report says 5000rpm at 60mph.
My buddy has a 88 is it came with 330,it was special ordered in Jan 1988,33k
When I bought the 89 there was his big bro 38 with the exact blue gel and interior,pretty cool seeing the 2 side bysideit was 119k
I guess the main reason someone in 1988 or 89 bought or ordered a 330 was cheaper.
Im betting wellcraft was puting the same motors in all the highperformance,scarabs,panthers,Spyders etc.
all had bravo ones
mine also came with some alum black mufflers on the inside, its made a diff when i took them off.
best i remember the intake has the dual carb bolt patern,the 365 came with a 800cfm quad.I think i still had the old merc repair manual.I seem to rememer the cam lift 510.
Attached Thumbnails What is the HP rating for a 1988 454 Mag motor?-robs.-picks-050.jpg   What is the HP rating for a 1988 454 Mag motor?-scarab-1989-28f0004-medium-.jpeg   What is the HP rating for a 1988 454 Mag motor?-scarab-1989-28f0019-large-.jpeg
Old 03-16-2012, 07:43 PM
Twin O/B Sonic's Avatar
Yep. I was selling boats in that era and standard 454 4 bl was 330 and the Mag was 365.
Twin O/B Sonic is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information -
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
