-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   1996 Scarab Fuel Tank Depth (https://www.offshoreonly.com/forums/scarab/277166-1996-scarab-fuel-tank-depth.html)
pippend 05-24-2012 01:58 PM
I have to replace the fuel tank sending unit on my '96 29 Scarab.The shop put in a Livorsi self calibrating sending unit, but it will not work with the stock guage. Rather than replacing one guage, I decided to try the Moeller Reed Switch sending unit which I believe works with traditional older style guages.
The tank looks to be aluminum and using a dipstick, I measure it at 12.25 inches deep from the bottom of the tank to the top of the tank. This is a 100 gallon tank. I plan to use the 10 inch sending unit which should show empty with a small amount of fuel remaining in reserve and not project too near the bottom of the tank.
I am posting this so others will know the depth of their tank as I could not find this information elsewhere.
k4armstrong 10-15-2012 12:05 PM
did you ever find this information, i'm needing to know as well. replacing my auto meters with livorsi and livorsi needs to know to send correct sender
