New to me scarab. Picking up this weekend.
I am picking up a 1989 scarab excel 28 this weekend anything I should know first when i hit the water. I am moving up from my wellcraft concept 23. Its Kevlar hull with drive moved back and Eddie marine trim tabs. I never had tabs so advice on how to use them would be Greatly appreciated.
Originally Posted by 88concept
(Post 3699393)
I have limited experience with them as well but that is how it was explained to me.... |
Yep.
Originally Posted by tmobileguy
(Post 3700719)
pushing the trim tabs down (usually the button facing up) will push the bow of the boat down and get you on plane faster... you can also disburse uneven weight on the boat by pushing the trim tab with the excess weight down as well...this will cause that side to raise up...you can find that sweet spot at WOT with them by raising them all the way up and keep pressing them down as you gain speed...once you start to slow down, raise them back up a bit until you are at the point where your boat is moving the fastest....
I have limited experience with them as well but that is how it was explained to me.... If you've not run a boat w/them before I'd start out w/them level w/the bottom and then get the boat up on plane and running before putzing with them. I'd assume they'll react fast similar to the Kiehaefer tabs so start out by just tapping the buttons and see how the boat reacts. There normally is a slight delay as well before the boat reacts to the change in tab position. Take your time getting used to what they do and you'll learn to love them. As described above, they are huge for stabilizing boat side to side when passengers move around. When I was selling boats I had customers that never used theirs because they'd never been taught how to use them and got scared when they tried and used way too much tab and got the boat squirley. Another tip too is that what the boat wants at 30 will be entirely different at 50 so you'll need to readjust as speed, condition, payload changes. Another thing you'll be able to do w/this boat that you couldn't w/o the tabs is in nasty, head on conditions you can put your tabs way down which will help keep the boat on plane at a lower speed (reduces pounding) and also put/keep the bow down so the sharpest entry point of the hull hits the wave first which drastically reduces the shock load to the boat and passengers. Congrats on the new ride. Should be a huge, positive jump from your previous boat. Keep us posted and you now owe us pix's ;) Gary |
Thank you so much for your wisdom i will try and load some pics if i can figure out how to do it i am not that great with computers. I will be taking it out tomorrow for the first time just to run it and get the feel of it before i start messing with things.
(Post 3701199)
You can make a Free account with Photobucket. |
1) WOW!! I dont think Ive ever seen an excel with the Miami Vice paint scheme! LOVE IT!!
2) Your boat looks brand new. Hard to believe its 24 years old! Congrats! Im seriously jealous!! |
It's got 400 hours on it. Always stored in a heated garage and the guy waxed it after every use. It's all original and in great shape. Has new 502 with work done to it. Now if I can get some nice weather to take it out and run it.
I see maine plates and no rust on the trailer-! Great find, my buddy just bought the same boat up here. -perfect int. But he'd **** if he saw that hull shine......
Great boat |
Wow!
(Post 3702038)
Very cool, and very rare pc regardless. You did good Son. PS, we need interior and motor pix's next. Looking at that bottom design too, w/the pad on it (like a Velocity), those tabs, that drive ad some power....., get ready ;) W/decent power that thing should be an absolute ball to drive! If that era of hull is well built, I'd be shopping for Bravo drives and big power right now! W/that pad bottom it's screaming for LARGE HP's. Would be the sleeper from hell too ;) |
(Post 3701662)
The Vice Colors are very nice! Excellent find!!!!! |
That is sexy! What a find! Good luck with her.
Thank you all. It has a bravo drive with nose cone. It has a fresh 502 with stainless marine exhaust had cutler injection but it now carb. Ported heads and cutler intake custom ground crane cam and full roller. 8.5-1 compression perfect for the procharger kit I have for it. I am just concernd about the stern jack and holding up. I will get pics of the interior it's not bad considering it all orginal vinyl.
Is that the boat on You Tube
Very cool!!!!!!!!
I asked when it was on you tube didnt get answer but what size and type prop is on it i have same boat different color thanks john
Wow that thing is clean! Congrats!!
Wow awesome find
| All times are GMT -5. The time now is 08:14 AM. |
