Prop sice for 29ft scarab with 600hp??
Hey Guys.
I am new on OSO. Nice forum by the way. I have a 29ft Scarab, with a 555cui 600hp as a replacement for my old HP500. What will the top speed be for a boat with that engine? I cant seem to clock more than 55mph with a 25in prop at 5000rpm. What sice prop do i need?? Regards. Jens Henrik Vinther. (Denmark) |
Jens,
Specifically what prop are you running? What outdrive and gear ratio? Was your engine dyno'd or are you estimating HP? Something would seem to be off somewhere. |
The engine was dynode 597hp at 5200rpm and 654lb-ft trq. I have the dyno sheet, and the engine was build specially for my boat, with a Comp Cam 11-451-8 marine cam and FAST EFI, and fresh water cooling..
The gear ratio I was told is 1,50, and i runs with a 25in mirage plus prop on a Bravo x with imco nosecone. The engine runs flawless, but no topspeed. Regards. Jens henrik |
Originally Posted by jens henrik
(Post 3725841)
The engine was dynoed 597hp. I have the dyno sheet, and the engine was build specially for my boat, with a Comp Cam marine cam and FAST EFI, and fresh water cooling..
The gear ratio I was told is 1,50, and i runs with a 25in mirage plus prop on a Bravo x with imco nosecone. The engine runs flawless, but no topspeed. Regards. Jens henrik 67 mph gps with a mirage plus 25p at 5000 rpmand with a bravo 1 26 lab i get 69mph at 5050 rpm all this # with std bravo 1 drive. With 600hp you should get arond 72 mph. Now the engine is upgrade at arond 650-700 hp and i get 78 mph gps with same 26p lab 4 blade prop at 5500 rpm. |
THX for your reply....Keep em coming :)
(Post 3725841)
The gear ratio I was told is 1,50, and i runs with a 25in mirage plus prop on a Bravo x with imco nosecone. The engine runs flawless, but no topspeed. Regards. Jens henrik Have you tried dropping to a 23 to see how high you can spin that? |
What do you mean when you say set-up and rigging issues??
Sorry if it is a stupid question, but i am pretty new at performance boating...:-). No i haven't tried a 23" cause the 25" worked well with my hp500. Can it have anything to do with the imco nosecone i have welded on my lower drive. |
(Post 3726901)
Sorry if it is a stupid question, but i am pretty new at performance boating...:-). No i haven't tried a 23" cause the 25" worked well with my hp500. To the point that you need to look at what has changed since then. If the 25 worked good with less HP than you have now but doesnt work well today, you have to ask yourself why? Can it have anything to do with the imco nosecone i have welded on my lower drive. At what rpm does the engine make peak torque? |
The dynosheet says 594,1 hp at 5200rpm and 653lb-ft trq.
And yes a wonder why it is slower with 600hp than with 500hp... Trust i am loosing my mind... |
(Post 3727065)
And yes a wonder why it is slower with 600hp than with 500hp... Trust i am loosing my mind... Are you making the 653 tq at 5200 rpm as well as peak hp there? |
