-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Should I raise the x dem? (https://www.offshoreonly.com/forums/scarab/285083-should-i-raise-x-dem.html)
indysupra 09-18-2012 08:33 PM
Boat is a 1996 31'. Im going to have some glass work done this winter just curious how much and if its a good idea? what are the pros and cons on this hull? boat has twin 502's with prochargers. Current cruise speed is about 63-64 out of boost and 86 top speed if any of that info matters. Thanks.
Eric
Tinkerer 09-18-2012 08:56 PM
How far is your prop shaft below the hull when the drives are parallel to the hull??
I raised mine two inches and thinking on going up two more.
Steve
indysupra 09-20-2012 07:45 PM
I will measure it tomorrow. Is that measurement from the lowest part of the hull?
indysupra 09-20-2012 08:23 PM
