80's Scarabs without Rot?
I have seriously looked at 3 scarabs only to finally discover signs of transom and or stringer rot (paid survey). I would like to find a mid to late 80's 34 Scarab III or 38.
When did the construction by Wellcraft improve on the Scarab models? Should I just expect all 80's Scarabs to have rot issues and plan on replacing transom or stringers? What other issues are common problems to that era of Scarab? I am now looking at 35 Cigarettes and Formula 336 and 357's. |
Originally Posted by deepv29
(Post 3798203)
When did the construction by Wellcraft improve on the Scarab models? Should I just expect all 80's Scarabs to have rot issues and plan on replacing transom or stringers? What other issues are common problems to that era of Scarab? I am now looking at 35 Cigarettes and Formula 336 and 357's. Jr. |
I am going to put my 31' Scarab Thunder up for sale soon. I just replaced the whole transom and everything else under the hatch.
I highly doubt you will find ANYTHING from that era that does not have some kind of rot. It does not matter if it is a Cigarette, Scarab, Apache or other. Some of the boat builders were better at sealing the holes that were drilled in the stringers and transom, but you have to remember that these boats are almost 30 some years old. Unless they sat in a garage and were taken out of the water every day, I would assume that the stringers and transom are soft. Your best bet is to find a boat that was already redone (like Glass Daves) And remember that even if a surveyor says that there is no rot, He doesn't have X-ray vision and cant see everything.
wellcraft build quality back then.... When I redid the transom on the nova I found air pockets and even an old cigarette lighter glassed in.....
Like others have stated i doubt u will find one that old with no rot. Heck most of the middle to late 90's boats will have some also.
Originally Posted by indysupra
(Post 3799306)
heck most of the middle to late 90's boats with have some also.
Original owner kept in garage no rot. Everything else is highly suspect!
90% of any older boat is goung to have some, a few do not, my Baja was rotted to hell, looked at my Cig and its not rotted at all, everything was sealed well in the Cig, the baja nothing was sealed...
It helps when they have been taken care of properly, my buddy sold a Scarab III last year and it has not been redone and it is dry as can be, but it was kept properly... thats a rare occasion.. |
Originally Posted by Full Force
(Post 3799734)
| All times are GMT -5. The time now is 12:33 PM. |
