-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Changing out the trim tab and drive cables scarab III 34' (https://www.offshoreonly.com/forums/scarab/295147-changing-out-trim-tab-drive-cables-scarab-iii-34-a.html)
laigle 04-23-2013 09:09 PM
Hey folks,
Finally getting ready for the season and of course noticed one of the trim tab indicators (mechanical) weren't working. :poopoo: So after taking a closer look:cartman: at the tabs(Mercury Kplanes) cable was split at the transom and the sleeve that connects to the tab was bent. I figure I may as well change them all out. Cables don't have serials or model numbers on them:daz:. Does anybody have specs on the cable length for the tabs? And recommendations on premium cables?
voodoo too 04-25-2013 08:54 AM
The cable numbers should be on the indicator end. Under the dash. I just ordered some from Mavic Marine. Good Luck!
F-2 Speedy 04-25-2013 09:02 AM
My 33 took a
22 ft starboard tab
24 ft starboard drive
26 ft port drive
28 ft port tab
good luck
laigle 04-26-2013 07:21 AM
Thanks for the information. Did you change them out yourself?
F-2 Speedy 04-26-2013 07:40 AM
yep, teleflex 3300 I think, same thresded connector on both ends,
laigle 04-26-2013 01:05 PM
ok thanks
