-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   502 oil temp/pressure issue (https://www.offshoreonly.com/forums/scarab/299427-502-oil-temp-pressure-issue.html)
Avs38 07-08-2013 01:07 PM
290 hours. 502 MPI, low oil pressure and high temp. For example, 3000 RPM, 20 lbs oil pressure, 210 oil temp. Other motor 40 lbs & 190. I believe old rule of thumb 10lbs for every 1000RPM? So last week changed oil, raw water pump and found semi clogged line coming thru transom. Removed and replaced ( pulled drive to do so). Ran great for one day, next day right back to above. Any input appreciated. Thanks
Full Force 07-08-2013 08:57 PM
cut oil filter open, make sure its not chewing bearings up..... if that's good, you have cooling issue...
Avs38 07-09-2013 08:24 AM
Will do thanks for your help
Avs38 07-27-2013 12:17 PM
fixed and running great. pressure and temp perfect.
bikepilot 12-21-2013 05:47 PM
I know it's been a while, but my 454 mpi is doing the same thing, what fixed yours?
