38 avs rub rail
Has anyone replaced vinyl rub rail with stainless?
3 Attachment(s)
Don't use stainless! You will never bend it. Here is the aluminum
http://cruisermarine.com/hollow-back...ess-steel.html hollow back stainless rail to hard to bend? My 31 bullet had stainless. Your boat is sick looking, great job. What power and speed? I just got 38 avs. Previous owner said 75 hand held GPS with 502 mag mpi out my 38,
http://tacomarine.com/item--1-1-4-x-...-A50-0199.html
540's just added boxes and -2 lowers. Playing with props right now. 84 at 4900. Handling is a huge difference |
Man I love your boat, that's awesome. My last boat I built 540s 625 horse cig bullet ran 80. So I'm pretty excited about having a step hull boat.
Not sure what I want to do for power this winter. Either swap 502 efi mag for 500 525efi motors or go thru 502s and put whipples on top of them.
hey dirtymoney you have any more pics of that boat? that thing is gorgeous
Here is my build thread
http://www.offshoreonly.com/forums/s...o-project.html |
thanks yeah i see that right after i posted that. great looking boat.
Hey DM - did you just swap out the insert or replace the entire rub rail? Not sure if the 33's and 38's have the same rub rail style, but I was told both pieces would need to be changed on my '99 38 AVS. The insert is pretty reasonable, it's the underlying piece the insert fits into that gets pricey.
i would love to see more pics up of stainless or alum. rub rails.
Swapped out the whole rub rail and not too expensive
1 Attachment(s)
[ATTACH=CONFIG]505310[/ATTACH]
Same paint scheme I started with!
2 Attachment(s)
Yes like yours it will be changed. Going to something similar to this.[ATTACH=CONFIG]505314[/ATTACH][ATTACH=CONFIG]505315[/ATTACH]
| All times are GMT -5. The time now is 05:23 PM. |
