-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   scarab 22 top speed question (https://www.offshoreonly.com/forums/scarab/306403-scarab-22-top-speed-question.html)
nautimarine 12-14-2013 09:52 PM
I bought a 96 scarab 22 hull and put a 454 mag carb motor in it that cam out of another one of my boats top speed the first time out was 65 on gps. I had sucked up water and barely made it back to the dock. Pulled the plugs and they were rusted. Pulled the risers and had puddles in the manifolds. Checked compression it was 150-155. Looks like it's been sucking water for awhile so is 65 good for an almost cooked motor and how fast should it run after redoing top end? Thoughts anyone?
Revd Up 12-14-2013 10:16 PM
I used to have a 96 Scarab with a 502 MPI. Boat usually ran about 72 on GPS. 70 on a slow day. 74 best day . Ran a labbed 25P Mirage Plus prop. It was lots of fun.
nautimarine 12-14-2013 10:25 PM
What rpm did you run with that prop? I used an old messed up re pitched small diameter 24 prop 5100 rpm 65 mph. To be honest i was hoping for more till i saw the inside of the heads. Im currently looking for the same prop you had.
Revd Up 12-14-2013 10:46 PM
The engine was all stock. I am thinking 5150, is the stock rev limiter? I was bumping on that. Don't know why, but mine ran faster than other 22's I raced. Just lucky I guess.:p
nautimarine 12-14-2013 11:07 PM
1 Attachment(s)
Think it will run faster after I fix this[ATTACH=CONFIG]514269[/ATTACH]
Revd Up 12-14-2013 11:19 PM
yep, that will help. While your in there might as well add some more HP.;)
fastscarab22 12-15-2013 09:44 AM
I have a scarab with hp465 in it , 731 cam ,merlin heads , dart intake etc Around 600 hp ,83 mph labbed 30 pitch
imco shorty little bottom work.
I think you might have to much cam its called reversion
nautimarine 12-15-2013 01:34 PM
Yea it is called reversion but i don't want it anymore.! Stock cam as far as I know. I started cleaning the heads today
MINK 12-16-2013 10:27 AM
My 96 runs 66gps max, 63gps avg. 24p 3 blade - stock 454 carb
I'd say you're right there.
nautimarine 12-16-2013 03:31 PM
at what rpm and is it a 454 mag?
Titan907 12-16-2013 04:42 PM
350 Mag MPI, Bravo 1, 23 pitch Mirage Plus, 64 on handheld gps.
nautimarine 12-16-2013 05:00 PM
Titan,what rpm was that?
Titan907 12-17-2013 01:41 AM
5200 if I don't end up doing a Procharger this winter, I am going to send my spare 23 to B Blades and see if they can find me a few more mph.
KWO361 12-17-2013 06:46 AM
454mag, 23P Mirage+, 4900rpm, full tank @ 63mph gps
MINK 12-18-2013 09:41 AM
Mine doesnt reference Mag at all so i'd say no, going off my factory tach it runs 4700 rpm.
Big Block 12-23-2013 07:25 PM
I have a set of heads that I built up for my 454 in my Scarab and never used. They are for sale if you need a set.
