starter issue 89 scarab
looking for ideas here/advice
port engine did start , run etc,, now with the key , it just clicks. i swapped ignintion switch, same thing. BUT, it will turn over just fine when i jump it at the starter??? so is there a fuse somewhere, or wire broke?? thanks flash gordon 89 38 scarab top mount starters trs drives |
Try jumping power at the slave solenoid, they are pretty notorious for failure. In fact, I think they have failed on all but one of my boats.
Originally Posted by donzi matt
(Post 4138628)
i even ran a wire from igntion switch starter sell...still just a click...click... i guess i could swap starter. is there another selenoid somewhere else.....?????????? thnaks... gordo |
There is a second solenoid, known as the slave solenoid. It takes the signal from the key and in turn sends a stronger signal to the starter solenoid itself. I don't know where it is located on your motor, but should be in the area of the intake manifold.
hmmmmm...i will look tomorrow...
thanks |
Just an out there consideration. I had an older 1977 Welcraft Nova. Chased poor starting issues all summer. Ended up being the big battery cables were old and not carrying enough amps.
well, found slave soleniod , bolted to a plate with large fuse right next to distributor. buying a pair tomorrow.
keep u posted. thanks for advice. |
Just try jumping across the two large studs to see if the starter activates. If so put a test light on the signal wire (I'm sorry I don't remember the color) and make sure it is getting power when the
well it was the 23 dollar slave soleniod. motor cranks over, now check valve lash, put few times back on, fire motors.
THANKS MATT!!!!!!! |
Good news! I keep a spare in my boat just in case.
