302 soft spot in floor
not my boat but my uncles. its a 2001 the spot is by the console. from what I understand this is common. whats is he going to face fixing this?
Some people will say to cut the spot that is soft and fix it that way, but if it were me, I will seperate the deck from the hull and fix it properly. Not to be a Debbie downer, but I could almost guarantee that there is alot more wet wood and soon to be soft spots down there.
Actually the top deck is usually very dry with only a couple small soft spots. If the rest of the boat stringers, bulkheads, transom are solid I would not split it. It would be a lot faster and a lot less expensive to just fix the small soft spots.
Probably lots more bad core in there.
http://www.boathaus.net/302-scarab.html |
Yeah , they are usually a lot worse once you get it apart . Usually starts around the console , for every soft spot there is usually a foot or two , if not more of rot . But most of the time it's all rotted out , just hasn't softened up yet .Picture scraping it out with a shovel . Boat Haus has re-done quite a few 302's , have seen his work on another forum . Does top notch work .
I'm looking at 302's and found this thread. Just wonder, what would this repair cost?
| All times are GMT -5. The time now is 10:22 AM. |
