-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Bravo XR (https://www.offshoreonly.com/forums/scarab/34291-bravo-xr.html)
SCARAB 10-04-2002 04:39 PM
Bravo XR
I have upgraded to BRAVO XR DRIVES AND NOW I HAVE A
HARD TIME PLAINING OUT. ARE THE XR,S A SHORTER DRIVE?
OR IS IT SOMETHING ELSE?:confused:
J-BOAT 10-04-2002 07:49 PM
Did you also change prop's?
SCARAB 10-05-2002 06:49 AM
No I put back on the same props,and I have the same gears
in the drives,and the same power.
audacity 10-05-2002 07:37 AM
what drives did you have? what h2o configuration did you have and what is it now?
SCARAB 10-05-2002 09:19 AM
I had Bravos that came on my 1991 31 scarab that were
hooked up to 365s. Sorry, but I have no clue about the
h2o configuration
audacity 10-05-2002 09:39 AM
you just bolted up XR's right on your 91 TA's???
SCARAB 10-05-2002 02:22 PM
Yes, I took off the old ones and bolted on the xrs. Everything
fit.
audacity 10-06-2002 05:50 AM
no, there is a dif....check with merc....your old setup used a castle nut and this one uses a spaner nut....who talked you into XR's....they eat way too much hp for your application...so you had to get new props? or you just changed inserts?
SCARAB 10-06-2002 07:47 AM
I plan to up grade the motors this winter,and Iwas having
problems with a drive , I ran across a deal on the XRs and
I thought it could not hert to put them on for the last of our
summer
audacity 10-06-2002 07:52 AM
what engine do you have and what are you going to (HP)?
