-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   scarab kv ssm#5 (https://www.offshoreonly.com/forums/scarab/347640-scarab-kv-ssm-5-a.html)
crazy canuck 06-14-2017 03:23 PM
scarab kv ssm#5
Just purchased my ssm 5's from gary kollofski for my kv this week, great guy to deal with . Who on here is running 5's with boxes no notch on a 80's scarab kv non Larry Smith ?
I will be running 900hp blower motors bam super cyborg trannies would like some input on your drive location setup and mph numbers running same power and or problems you experienced, any information would greatly be appreciated .
Mark
hblair 06-16-2017 04:39 PM
Sounds like a lot of fun. Looking forward to this...
CIG3 06-18-2017 08:58 AM
What boxes are you running. If they are the mercury adjustable boxes I would start with the drives 1" below the bottom with the boxes in the center hole. That way you can adjust up or down and inch. The 38 KV I raced back in the day liked the drives an inch above the bottom but is was super light.
crazy canuck 06-18-2017 07:22 PM
HI Heath, boy you really ripped her apart going to be brand new ,the flat decks are worth redoing such nice lines on them . CIG 3 yes they are the Mercury adjustable boxes , I had a similar thread few months ago about x dimension on the kv with #3's . Team Archer (Dan) chimed in and suggested 3" below and 17.5"-18" prop since the bow is heavier . I have spacers that I got with the drives so I think I am going to set the "x" 3 below with 1" spacer installed and the gimble on bottom hole of the boxes so I can pull spacer out and move gimble up when I test props . Thanks for the input .
Mark
Team Archer 06-19-2017 11:15 AM
Mark are you running number Vs or IIIs ? the number Vs can run a lot higher than the IIIs We are running a 79 Larry Smith with VIs at 1 inch above the bottom with the number Vs on boxes I would start at 1 inch above the bottom at neutral on the boxes witch allows you to move up or down. If you have any questions feel free to give me a call. Regards Dan
crazy canuck 06-21-2017 09:38 PM
Thanks Dan for letting me pick your brain on the drive set up .
Mark
endeavour32 07-26-2017 10:09 PM
Have you set your boat up with your number V's yet? The set up, I'm about to install is very similar to yours, other than I have a notched transom. If you set it up 1" above the transom, I'm curious how it worked for you.
crazy canuck 07-28-2017 08:10 PM
Rigging transom this winter i will post pics of my work
Mark
endeavour32 09-14-2017 06:44 AM
2 Attachment(s)
Were/are you running intercoolers on your blower set-up? I received my engines last week and I'm having doubts they will fit under the races hatches. I had planned on raising the X 3", in order to get the prop shaft 1" above the bottom, but now I'm just hoping I can get the race hatches closed with the engines at the stock location. With the adjustable boxes I should be able to get the shafts 1" below the hull, which won't be ideal, but at this point, it is what it is.
Team Archer 09-14-2017 01:34 PM
2 Attachment(s)
Just rebuild your dog houses taller nd no one will no the difference.
endeavour32 09-15-2017 06:54 AM
I was thinking about doing that. Ha, I'll add that to the list of projects.
Team Archer 09-15-2017 11:55 AM
What else are you going to do this winter
crazy canuck 09-15-2017 12:29 PM
i am not using tthe factory race hatches using pro stock style hatches that came with the boat so there won't be a problem when using chillers . Starting my x at -1 " center hole on boxes and going from there . I bought 1" and 2" spacers along with my ssm 5's
endeavour32 09-15-2017 04:00 PM
Entire cabin is getting redone, replacing the transom, and then if there is time, prep the boat for Glass Dave to paint. This may be a two year project before it hits the water. I'm curious to see what crazy canucks boat likes, as it's a fairly similar set up.
bck 09-15-2017 11:01 PM
Hey Dan, my drives are even with the bottom with a spacer on them. Did you guys ever do any testing without the spacers or do you figure it was well sorted out long before it made it's way out to you?
Team Archer 09-16-2017 11:54 AM
I believe that the boat was set up for the Catalina Ski Race. That's why it has the spacer in the drive to keep the rooster tail down and to get on plane faster. I don't remember that was a long time ago and we were still racing back then and testing 2 to 3 boats a week.
bigfarmer 09-16-2017 01:42 PM
Have a set of 2" spacers and studs if you need some
bck 09-16-2017 10:03 PM
Thanks, makes sense. The guy that owned it back then changed his email address and that was all I ever had to contact him.
Team Archer 09-18-2017 12:41 PM
His name was Jody Martin. the last time I worked on that boat was 2004. Looked back old invoices we never played with drive spacers just trying to get motors running good.
