Scarab 33AVS Rub Rail inser?
Hello everybody.
i am looking to replace the rub rail insert of my scarab 33 avs, due to normal wear. It is the only thing not “fixed” during the restoration. I measured the insert and it is 13/16” or 2cm (as we look at it on boat) and 7/8” or 2,3cm aprox at the deep part that is inserted. it looks like this but with different dimensions. https://www.wholesalemarine.com/taco...b-rail-insert/ i am located in Greece, and in my country they dont use this size, so i cannot find it. do you know where i can find this specific rub rail insert? Does anyone of AVS owners replaced this insert (only)? Color, black or white, its ok, no preference. *the boat is black under the rail. thank you very much! And that’s my AVS (with windlass that confuses), came out for early sunbathing some days before the quarantine. https://i.postimg.cc/7LDTvtSH/F25-A2...-CCC557278.jpg |
https://www.wholesalemarine.com/sear...ub+rail+insert
this what you're looking for ? they also have it in white |
Probably yes!
i will email them for info and i ll let you kmow if it is! thanks for the reply! |
Thanks for the advice. I mailed them, ordered, everything ok!
| All times are GMT -5. The time now is 03:15 PM. |
