Engine options
Was a big block chevy engine optional in a 1986 scarab1 - 21'?
Spec sheet says "Max. Horsepower: 260", then on the options list, it didn't mention engine upgrade, so I'm not sure if someone special ordered it, or swapped in more power. Dan at Archer Marine could probably answer that question off the top of his head!
4 Attachment(s)
I don't have an '86 brochure, but if its the same hull as the attached image from 87 or 88, just without the integrated platform.
As far as I know Wellcraft never offered the 21 with a big block.
Short answer is no
[QUOTE=phughes69;4787711]Short answer is no/QUOTE]
t |
Thanks, here is my delema, i recently bought a 1986 scarab 1 with alpha 1 outdrive (inside of boat) with other misc parts, and big block chevy exhaust manifolds with risers and was told the last engine in it was a bbc, however the thru hull exhaust holes in transom are in stock location, i just picked up a 454 short block but wondering if i would be better off installing sbc and selling the bbc parts
Really depends on your budget and goals. If you keep the alpha drive, go with a small block.
get up to ten posts and post some pictures |
Scarab 1
Originally Posted by resurrected
(Post 4788695)
I had the newer model, a 1989 w/SBC and I think they optioned BBC/330hp starting 1990. Not sure if hull bottoms were the same, but mine had a pad.
Scarab 1 engine options
Has anyone put a high revving 302 chevy small block in a 21' boat
Originally Posted by Jim Fletcher
(Post 4788736)
(Post 4788712)
Ive seen a few of the members scarab1 boats & mods turn out really good, & wondering if anyone has one of these older 21' scarabs with the bbc installed & if it drastically changes the handling characteristics of the boat, also the boat does not have trim tabs, are they a must with a big block?
The big block wasn’t offered before merc had a good option for a drive without a transmission. Bravo drive wasn’t available until ‘88.
plenty of later small block options that don’t include the old school thought of a dz302 |
Originally Posted by bajaman
(Post 4788760)
Not sure how relevant this is...but just throwing it out there...I have a 21' Baja with a big block in it, it does just fine without tabs. It's got a 17 degree deadrise...not sure how that compares to your Scarab? Weight is around 3,500 pounds.
Engine options scarab 1
Ok i hope im not entering this twice, but when i submitted it, it disappeared, may have deleted, i am new here and hope this isnt a dumb question but just like tricking out a motor & making it twice as good, can the alpha 1 outdrive be "tuned up" or made better like maybe spin balance shafts, gears, upgrade to harder metals at weak points. And curious what is a ballpark figure to upgrade to the bravo 1?
I don't know of any modifications to improve the strength of the Alpha, it's just plain small. I have sold used Bravos with transom assy in good condition for $3,500.00. Good used parts are out there, you just need to be patient.
(Post 4788736)
(Post 4788775)
what kind of speed does it run, & u pull skiers also?
I am going with the bbc 454 that i have, and is the starter in different location for marine use, can a truck block be retrofitted ?
I’d stay with the BB and add a Bravo drive and you’ll be happy for a long time. Replace as much cast iron off the BB with aluminum bits and you should be close to the oem small block.
Caveat: I really know Jack **** of what I’m talking about but that would be my path to explore. |
Originally Posted by phughes69
(Post 4787711)
Short answer is no
Im trying to use the flywheel cover that came with boat, also trying to id if block it mark IV or gen V, it has a fuel pump mount but block off plate bolted to it and also has hole for crank sensor on bottom of timing cover ? Any help appreciated
starters are in the same location on a SB and BB, unless a top mount rear CCW starter is used in a trans application
https://cimg4.ibsrv.net/gimg/www.off...8dfd49d7d2.jpg
1st time tryin to post pic. Here she is old but solid transom |
^ looks good!
(Post 4789525)
https://www.mercruiserparts.com/part...ndrive-inboard |
Thank you
Merc had 330hp BBC in front of Alphas for a couple of years. Late 80s maybe? waiting on the Bravo. A friend had one he bought new that lasted until he decided he wanted to hop it up quite a bit, then it didn't make the next summer. :(
| All times are GMT -5. The time now is 08:51 PM. |
