-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   1995 29' Anything to look out for? (https://www.offshoreonly.com/forums/scarab/45930-1995-29-anything-look-out.html)
rainmn 03-21-2003 10:33 AM
As the title suggests, it looks like I'm going to check out a '95 29 Scarab next weekend. Is there anything in particular I should be looking out for? Any known problem areas to be aware of?
The boat is a twin 350 model, only 200 hours. Other than that, the broker couldn't give me too much info. It is bottom painted, and was used in salt water.
What's a good guess on what it's worth? They're asking $35K. Nada says avg. retail is 32, low is 25. I'm figuring the bottom paint alone puts it closer to low, even if the boat is mint.
29scarab 03-21-2003 12:50 PM
I have a 96 I run in salt water. Mine has a supercharged 502 in it. I would check for corrosion on the wiring back by the engine. Check the wiring by the starters if you can see them. I had a friend with twins that the shifter cables kept binding and breaking.
Have someone do a compression check on the engines and also check exhuast for corrosion. I flushed mine at least for 20 minutes before I put back in storage. Check the drive oil, engine oil. Check where the porta-potty is, in front by the V-birth for mildew etc...
Anymore questions, feel free to email me!
If it all works out, Welcome to the Scarab team!!!
rainmn 03-21-2003 01:09 PM
Thanks for the info. If it looks good initially, I'll have a survey done, but these are good things for me to check out beforehand.
What speeds do you see with your set up?
powerguy 12-31-2003 02:56 PM
did you ever see the boat? I am looking at a 29 scarab now without power and I don't have a clue as to it's value?
thanks
jb 01-02-2004 12:33 PM
94 -96 no power..20 - 25 k tops in great shape twins..
Let me know if you dont buy, I have an interested party
jb 01-09-2004 07:26 AM
news?
DirtyMoney 01-15-2004 08:58 PM
PM me I may have the boat for you with a single 454 and a bravo that is immaculate
tssteph 01-16-2004 09:56 AM
There is also a 2002 with a single on Ebay right now.
