-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Scarab Panther Questions (https://www.offshoreonly.com/forums/scarab/48048-scarab-panther-questions.html)
engreps 04-18-2003 02:29 PM
Scarab Panther 30'. Looking at two boats. One is a 1986 and the other is an 1988. Both with 454's and Bravo 1 out drives
How do these boats perform?
What speed ill they run?
Are there any problems with these boats?
Anything special to look for?
Both boats have small trim tabs. Would K Planes help the performance?
Any help would be appreciated.
SCARABJ 04-18-2003 11:25 PM
I have had a 88 panther since 1993 I have been 98 mph in mine with 800 hp kieth eickerts and short lowers. I have had 5 diff motor combos in the boat and 3 diff drive combos. I just finshed up with the swap from my new boat I took my big eickerts out and put in the 502 mag mpis gimbles and drives also out of my 99 33 avs with that power it runs 76 mph. If you are looking to buy one call me and i will e mail some pics and specs james 904 545 4821 jax fl.
Panther 04-24-2003 08:35 PM
The mid 80's Panthers had problems with the bottom. They didn't overlay the glass to well on the keel, thus it made the center of the boat weak. You will see a lot of stress cracks just under the lower chines on both sides. The later 80's Panthers didn't have this problem. I have an 86' Panther with 550's and the boat runs close to 80mph with TRS'.
I would go with the 86, since it may have Bravo's??? It is a fun boat to drive, but maybe a little too much pounding in the rough stuff. Of course size is a factor, but I have riden in a lot of 30 footers, and the Panther definetely qualifies as a pounder with the TRS setup. I haven't driven a Panther with Bravos, so that may be different.
Other than that, they handle well, and are very predictable. Re-entry is predictable, and you know when the boat is going to leave the water (at least I know, unlike others who can't drive).
If you have any particular questions don't hesitate to ask? I have had mine for over 4 years. I have done a lot of work to it, including blue printing the bottom, and a lot of work with the keel because of delam from what I mentioned above..
Panther
Panther 04-24-2003 08:37 PM
Oh yeah, put on the K-planes. Panthers need them, especially for planing off, and rough seas.
Panther 04-24-2003 08:44 PM
You can see pictures at: http://mysite.verizon.net/vze4jgbw/
Mintish Panther 11-15-2003 06:54 AM
1 Attachment(s)
My '89 30' ran 68 recently w/ stock 454s and B1s. I don't know the hp ratings, - I'm trying to learn more about this boat. I got k-planes but have not had to use them much since I'm at LOTO.
Panther, I get this w/ your link;
"Locked
The requested resource is currently locked. The lock must be released or proper identification given before the method can be applied."
I'd love to see detail pics of your boat.
Strip Poker 388 11-24-2003 04:25 PM
In 1989 the motors were 330 hp or 365 on the 454
Mintish Panther 11-27-2003 11:51 AM
Hey, Strip, -correct you are. According to the 1989 Retail Price Sheet I just received from Wellcraft, the "454 Magnum (365)" was an $8,450 upgrade compared to the $60,795 base price "7.4 (330)".
What are the differences between the two motors besides the "special high-performance exhaust" that is footnoted as included with the 365hp? Is there any exterior evidence that I can tell mine are the bigger horse motors?
Strip Poker 388 11-27-2003 06:02 PM
The exhaust was the same .The 365 had steel crank, 4 bolt main block,7/16 rods, forged pistons , the cam was a 510 lift,The heads were rectangle port, better springs . the intake was a dual plane medium rise intake ,800 cfm quad carb
The 330 hp main diff was cast crank ,small rods, oval port heads,
In my Scarab the stock bottom end of a 365 horse. With mearlin heads and 8/71 blower it made 762hp on the dyno . It held up good. The 365 hp motor has the same basic parts as a 1970 454 LS6 motor that came in the chevelles :D :D
Mintish Panther 12-01-2003 04:42 AM
Good news, and . . . Long Live Chevy!
I just winterized this w/e, and guess what I discovered showing on those plastic carb covers? 365 Horse! Woohoo!
Rookie 12-04-2003 02:54 PM
Does anybody have any suggestions to help reduce the pounding you take in regards to maybe a prop selection. More bow lift? stern lift? Minimum k-planes lengths?
I have tried 4 blade 25 pitch cleavers to help get out of the hole better, excellent choice for that. but it seemed to push my bow down and go through the middle of the wave. also lost to many mph's.
I'll be rewiring my k-planes so they will usable for next season.
Any info on the setups of all of you panther owners would be greatly appreciated. I have '86 panther, 454's built a little, TRS, old 3 blade ? brand props @ 25pitch, 5100 rpm's @ 71.6 gps
ridethis 12-05-2003 05:12 PM
FOR SALE
I HAVE A 1989 SCARAB PANTHER THAT IS ALMOST REDONE I THINK IM GOING TO SELL IT ANY SUGGESTIONS
Mintish Panther 12-07-2003 06:55 AM
1 Attachment(s)
I don't know your location, - Where is the boat? What will be your asking price?
My Panther has gotten lots of interest in the short months I've owned it so far. Pictures showing condition are sometimes better than pages of description. If you E-mail pics I'll show them to friends who have places at LOTO and can get the word out in case your boat is anywhere near there.
St. Louis' Boat show is coming soon and the buying fever builds from there for next season.
Besides, I would appreciate any shots of your Panther for archive reference for myself.
[email protected]
Denscarab 07-19-2010 09:22 PM
Help needed
Panther
Would you be able to contact me to discuss what props you are using? Email address is [email protected]. Denny
Panther 07-20-2010 01:42 PM
Are you freinds with Jersey Steve? He asked me some questions as well, just sounds like you may know him.
I don't own the Panther anymore but I'll send you an email with my contact info and would be happy to help if I can.
Frank
Mathbychoice 07-23-2010 08:20 PM
You said that you had your 30' scarab in the upper 90's what type and pitch of propps were you running? I have a 88 panther with the 365 hp upgradded factory motors and bravo drives. I would appreciate all the information on the things I need to do to reach the 100 mph + mark. If it is possiable. I do know every thing is possiable with enough money, I'm talking with surpassing the value of my boat.
