Ya Have Twins And Ya Loose One ?
Will a 29 scarab with stock 350 mpi's and bravo 1's come on plane with only one engine. And if so do you come in that way or do you limp home ?
Re: Ya Have Twins And Ya Loose One ?
It may do it but it will be real hard on the other drive.
I tried it once with my 34 and I could get it on plane but I was almost at WOT with the other engine. |
ABsolutely will not work with mine. I have had more than enough practice limping home :(
I tried it with my 30' but it seemed to work the other engine to hard and I knew it was hard on the drive so I really didn't try it to long.
Limp home before you break other things. |
I can stay on plane with one engine, but I can't get on plane with one engine. If i burn up a sea pump, I'll use it long enough to get on plane, kill it, and take it out of gear.
| All times are GMT -5. The time now is 02:57 PM. |
