Pachanga 22 project Wet-Vett
1 Attachment(s)
I have an 1988 Sea Ray Pachanga 22ft
Dry weight 2800 lb. SB Chevy 400 +30 over 406 ci 10.0:1 Compression ratio Index and Complete balanced rotating assy. 100 octain Race Fuel 650 Holly Carb with a QFT quick set vacum secondarys Elderbrock Hi Rise Dual Plain Scat Crank FORGED 4340 LIGHTWEIGHT PRO COMP Scat Rods 4340 FORGED I-BEAM ROD with ARP 3/8" Thru-Bolts SRP INVERTED DOME Pistions 139625 Dart Eagle Cast Iron Heads 180cc/49cc Manly 3 Angle Valves, 2.02/1.60 Scorpinon 1.6 roller tip Rockers Howard Cam FT H230/240-10 Canton Oil Pan 8 quarts Clayes Gear Drive Replaced cerulating Pump w/ Cross over Mercruiser 1.47R w/ hydomotive nose cone. It gets to 60 real fast then falls on its face, was hopping for more like 79- 80 mph.. any suggestions. |
ya mine took 550hp to get to 80
Was the engine dynoed? You may not have enough gitty up to see that speed. My pachanga has a bone stock 330 horse 454 with a alpha ss, spinning a 25-3 blade 67.4 mph. I would think you would be faster than me. :(
Never dynoed the motor, engine builder claimes its pushing 450 + HP. Whats got me is that originally I had a stock 350 that came with the boat at the time I bought it. And I was getting 65 mph on the GPS with a Quicksilver “cleaver” propeller (3) blade, stainless steel , but I spun the baring doing it.
RBT... BB or SB? and what do you have for parts?
Originally Posted by Megabite
(Post 2200479)
i hear ya megabite
89 p-22,454,30 over,blower pistons,7:4comp,eagle sir rods,merc525sc cam,flat tapplat,merlin 2 heads,310runners,stainless exaust,tbs250 blower,6pounds boost,1050 domanator carb,msd dis/box/rev limiter.30 degrees timming.28p bravo1 prop.i am guessing around 500hp.best gps 78 at 4700 rpm......drinks gas like no tomorrow.go figure.....?
I am running a 496, 25P Mirage Plus 5,000 RPMS and 75GPS
with a full cooler of beer:cool-smiley-027: |
(Post 2200479)
Dry weight 2800 lb. SB Chevy 400 +30 over 406 ci 10.0:1 Compression ratio Index and Complete balanced rotating assy. 100 octain Race Fuel 650 Holly Carb with a QFT quick set vacum secondarys Elderbrock Hi Rise Dual Plain Scat Crank FORGED 4340 LIGHTWEIGHT PRO COMP Scat Rods 4340 FORGED I-BEAM ROD with ARP 3/8" Thru-Bolts SRP INVERTED DOME Pistions 139625 Dart Eagle Cast Iron Heads 180cc/49cc Manly 3 Angle Valves, 2.02/1.60 Scorpinon 1.6 roller tip Rockers Howard Cam FT H230/240-10 Canton Oil Pan 8 quarts Clayes Gear Drive Replaced cerulating Pump w/ Cross over Mercruiser 1.47R w/ hydomotive nose cone. It gets to 60 real fast then falls on its face, was hopping for more like 79- 80 mph.. any suggestions. Switch to a single plane, like a Dart. And I did not see what kind of exhaust, stock? |
I'm interested in propeller experiences on this boat.
I have installed a 496 HO with Bravo 1.50 ratio drive in a customer's P-22. The prop was a Bravo I 24p out of the box. The prop delivered a great midrange and hit 60 kts @ 5k rpm (69 mph), the boat was steady with a slight tendency to chine when hitting top speed. The prop was a great choice in regards to the guy being a little older and not a top skilled driver :D My own P-22 has a HP 450 clone with Bravo I XR drive, 1.50 ratio. Ignition system will allow the engine to rev up to 5250 before hitting limiter. Due to unavailability of B1 24 p I took a chance and tried a 26 p instead. The boat accelerates at least as good as with the 496/24p but it feels like running higher with the stern causing the boat to chine walk already at 63 or so mph. I was thinking about labbing the B1 to get some bow lift but it looks like 1BIGJIM has the prop key to speed. How does it run at top speed? Any other suggestions? |
