-   Sea Ray (https://www.offshoreonly.com/forums/sea-ray-224/)
-   -   IV Pachanga (https://www.offshoreonly.com/forums/sea-ray/189065-iv-pachanga.html)
Flamingo 42 06-16-2008 10:09 PM
IV Pachanga
I own a '87 32 Pachanga in the Sea ray archives my boat matches whats listed as a IV pachanga, anybody know anything about this?
Flamingo 42 06-17-2008 08:17 PM
mmmm no input from anyone, whats so different about my boat from others ive seen is the vents, there are four small ones up high instead of two down low. '89 is the first Sea Ray kept records but the brochure is the same.
estarmer 06-18-2008 05:23 AM
What information are you looking for? Sea Ray made 4 Pachanga's back then 19', 22', 27', and 32' so the 32' was the 4th which I believe is the reason for the IV designation.
Depending on options you should have 3 and up to 4 thru hulls on the port side. and 7 on starboard including the horn, this includeds a drain forward if you have A/C. The differences you've seen were likely option related.
Hope this helps
Eric
If you have specific questions I may be able to look it up.
Flamingo 42 06-19-2008 09:03 PM
I've been trying to find the manufacturer of the vents, I'm missing one. All the other Pachanga's have a different type of vent but in the archives on the Sea Ray site they list a IV pachanga with the identical vents on mine. I was wondering if anyone knew what the difference was.
ext2gtx 06-20-2008 02:08 PM
witch vents are you talking about the engine bay vents,and like estarmer said they have different options as big blocks small blocks paint and so on. i have an 87 32 also
Flamingo 42 06-23-2008 09:39 PM
My friends 32 is the same year and his has the same twin 454 setup, his airbox setup is mounted lower and only has two vents per side not sure if the IV is a different option or not.If you go to the sea ray site choose the length that covers the 32 and go to arcives and you can see the picture of the IV
estarmer 06-24-2008 05:39 AM
if you can get me a pic of the vents in question I can check some old prints and see if I can get you a part number.
Flamingo 42 06-25-2008 10:06 PM
I will post some pictures , just need to figure out how to load them
Flamingo 42 08-09-2008 07:55 AM
After 4 years I found the vent I was looking for, with no luck looking through old records at the SeaRay dealer a long time mechanic walked up and identified the vent as a cut down version of a common SeaRay vent went to another dealer with NOS stock and they had ONE. Cant belive SeaRay hand cut and fit eight vents on a production boat unless it was a speacial production!!
ext2gtx 08-09-2008 07:27 PM
we need pics
Tristar Racing 08-10-2008 10:02 AM
I would imagine the production version was molded as the shorter version, and the mechanic had a good eye and realized he could cut down one of the longer more common ones...
Flamingo 42 08-10-2008 08:40 PM
I will try to download some pics, couldnt get it to work before but I will try again
Flamingo 42 08-10-2008 09:20 PM
2 Attachment(s)
heres some picsAttachment 355352
Attachment 355353
