-   Sea Ray (https://www.offshoreonly.com/forums/sea-ray-224/)
-   -   tambour doors (https://www.offshoreonly.com/forums/sea-ray/209945-tambour-doors.html)
ext2gtx 05-31-2009 08:38 PM
tambour doors
Has anyone had to replace their tambour door track, and if so where did you get the track from. thanks mike
ext2gtx 06-08-2009 07:26 PM
no one has anything
1BIGJIM 06-09-2009 03:11 PM
Whats wrong with the one you have?
ext2gtx 06-09-2009 04:28 PM
broken need to replace
scarabman34 06-11-2009 10:37 PM
Whats a Tambour? Is it like a green tamboureen?:lolhit:
But really, what is a Tambour? sounds french.
Flamingo 42 06-15-2009 06:27 PM
It's the flexable sliding doors in the cabin, mine are starting to go bad so I'm planning on making some from some leftover matterial from my cabinet maker friend
ext2gtx 06-16-2009 06:11 PM
i'm looking for the plasic track the door runs in.
Flamingo 42 06-16-2009 08:52 PM
I had one broken and glued it with some gorilla glue and supported with some aluminum strips, its holding pretty good
Dreaminbig 07-07-2009 04:27 PM
I have the same problem. Did you ever come up with anything? Sounds like guerrila glue may be the best answer!
ext2gtx 07-08-2009 04:47 PM
I have found them but you have to buy ten pair,so i have a friend that work at a sea ray dealer and he is going to see if something from another boat may work.
