Who's the best at reprogramming ECU's >
Old 12-07-2004 | 12:01 PM
Smitty's Avatar
Default Who's the best at reprogramming ECU's
Hey Guys--
I have some 502 Mags that I am going to go thru this winter and refresh. Along the way I am going to install different cams and I need to know who is the best at reflashing the ECU for modifications.My motors are Gen 6. I already have CMI headers. I will also most likely be going to aluminum heads to gain some power. The stock heads are not bad, but I can buy some bolt on aluminum heads that already have the good valves and flow alot better than the stockers.
Let hear who's the best !!!!
Smitty is offline
Old 12-07-2004 | 01:13 PM
Default Re: Who's the best at reprogramming ECU's
Call Mark @ Precision Marine at 504-469-7463 and tell him You got his # from Sean@Aftermarket Marine
amarket1 is offline
Old 12-07-2004 | 02:28 PM
throttleup's Avatar
Many of my clients have used Precision as well.
Julie
throttleup is offline
Old 12-07-2004 | 03:01 PM
articfriends's Avatar
Tyler Crockett Does ecu's and you deal directly with him,nice guy 810-324-2720
tell him smitty reccomended him,Smitty
articfriends is offline
Old 12-07-2004 | 04:37 PM
Breathe Later's Avatar
Bigwavzs,
Try Ron Harris at Livorsi. They're over in Grayslake. He does the units for their coolcharger systems. BTW, you might remember me from the River Shiver in 2003. I've got the 27' Fountain with a Whippled 502, CMI's, Teague heads, etc. Also, please consider our club, Northern IL Offshore Club.
Best Regards,
Mark S.
Breathe Later is offline
INDY27's Avatar
I used Mark @ Precision Marine also, as well as many of my freinds and there is nobody in the business better than him!
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 12-07-2004 | 05:52 PM
gLaSs HaLf FuLl's Avatar
Bigwavs goto www.azspeed-marine.com from what I understand they have done a lot of reprograming on the 502 mpi's.
Breath later "Mark" stay tuned next spring for bigger better things than nioc. Some
of us are planning the fun minus Bruces BI Laws.
gLaSs HaLf FuLl is offline
Old 12-07-2004 | 06:31 PM
Smitty's Avatar
Mark,
I will call Ron. Hey we missed you at the Shiver this year. It was a blast. They had a guy taking digital pics. I got some awesome shots of my boat. It was a great way to end the season as I have sold my boat. I have moved up to a 36 Outlaw. When I am done hopefully I will be able outrun Ya
See Ya on the water in 2005 !!!!!
Smitty is offline
Old 12-07-2004 | 07:55 PM
Strip Poker 388's Avatar
i have had my ecm's done by Jim at azsm and had problems with them ,sent them back 2 times ,His fix just richend the fuel map all the way thru it . The boat slowed down, I gave up on him.Just ask around and do a search on Arizona here.
On my new project Mark at Precision Marine is going to program and dyno My engines .His is real helpfull and is not short with ya on the phone like most.
Strip Poker 388 is offline
Old 12-08-2004 | 05:43 AM
Canada Jeff's Avatar
My advise, talk to the reprogrammers before you buy your parts! Each reprogrammer mentioned above has their own idea about how the engienshould be modified for the best results. These builders reprogram the ECU's knowing what has been done. If you build them up, and simple tell them what you did, it may be different than what they would have done in the past. Witch in turn may complicate the reprogramming!
So if I were you, and I was last year making calls and researching, go with the builder that has a proven package and change what they suggest! That way you know it will work, and if there are any questions, you will be less likely to be left out in the cold!
Canada Jeff is offline
