Blower motor total timing?? >
Old 12-02-2005 | 09:03 AM
Default Blower motor total timing??
What's the safest timing and best performance for a blower motor with the following specs? 540 ci., 8:1 compression, 1071 intercooled with 1050 dominators, 7-9 lbs. boost full MSD. Usually run on 92-93 octane w/ VP octane booster. I've had so many different opinions, I thought I'd inquire who's running what and what is living??
37Talon is offline
Old 12-02-2005 | 11:13 AM
WildWarrior's Avatar
Default Re: Blower motor total timing??
What is your duration at .050? What is your lobe separation? Iron heads or Alum? Are you sure this motor has 8 to 1 compression? Where is your intake centerline? A base line should be around 32 degrees.
WildWarrior is offline
Old 12-02-2005 | 11:52 AM
RLW
I was running 29 degrees locked on a 468 with B&M 250. I was pushing about 5 Lbs. boost. This was a recommendation from Nickerson.
RLW is offline
Old 12-02-2005 | 12:10 PM
Charter Member # 1083
I know I'm very conservative but, I'm also around the 29* mark. I have aluminum heads 8:1 compression and 5 lbs. boost. I always run 92-93 octane. I think that B&M states that you only loose a very small percentage of peak HP with the total set at 28*.
If it's not a thunder run.............than you're just burnen fuel!!!
BOB ONEIL is offline
Old 12-02-2005 | 12:23 PM
Smitty's Avatar
I'm at 30 degrees at 8 psi at 5400 rpm. I'm also EFI which helps a little.
Smitty is offline
Old 12-02-2005 | 12:27 PM
racinfever's Avatar
lesser total timing #s show better hp# on the dyno but in your boat
more timing is better ,if you can tune it safely .
lower total timing can cool exhaust temp on dyno pulls ,in your boat you run much longer than a dyno pull & start to increase exhaust temps . a good place to start is 32 total.
racinfever is offline
Old 12-03-2005 | 08:03 AM
KNOT-RIGHT's Avatar
32 Locked
10 lbs boost intercooled
547cu
cast iron heads
741 roller
93 octane only
too low............. Hard on exhaust valves
too high.............. risking detonation
Gerry
KNOT-RIGHT is offline
Old 12-03-2005 | 08:19 AM
zt260's Avatar
My timing is computer controlled. Presently it’s programmed to 28* at WOT, 10Ibs at 6000-6500rpm. At lower boost levels or rpm it's set as high as 32*
For your application I would be looking at 28-30* at WOT provided your intercooler intake water temperature is 75* or less. If you’re looking for a specific number I’d go 29*
IMO, detonating an engine is much worse than replacing exhaust valves. I have 70hrs on my 540 Quad rotor with these settings. No timing issues to date.
zt260 is offline
Old 12-03-2005 | 09:54 AM
Commander112's Avatar
I also have a 540 (9 to 1 comp, alum heads, 10-71 w/innercooler). I have gotten best perf and ease of starting when the MSD distr was locked out at 30 degrees.
Commander112 is offline
Old 12-03-2005 | 11:41 AM
557ci...8.0:1...Alum heads...10-71's at 6.5psi....30* total, all in by 2500rpm.
Back4More is offline
