Oxygen sensor install >
Old 04-14-2006 | 04:19 PM
nordic95's Avatar
Default Oxygen sensor install
Hey guys check out this idea.I wanted to install sensors in my wet exhaust.I didn't want to add a spacer like other member here have done because of height restrictions.I had my welder drill an 1.5" hole thru the outer layer into the water passage and then fill hole with weld to create a sleeve.Then we drilled and tapped into the center of the weld the for the oxygen sensor.Now I can just use a plug to plug the hole when I'm done testing.When I make changes to the motor in the future the hole will always be there for future testing.Now I just have to get this thing running to see if it will work.
Thanks Nordic95
Attached Thumbnails Oxygen sensor install-100_0542-medium-.jpg   Oxygen sensor install-100_0541-medium-.jpg   Oxygen sensor install-100_0538-medium-.jpg
nordic95 is offline
Old 04-14-2006 | 07:06 PM
Default Re: Oxygen sensor install
Nicely done. How much to do others?
cobra marty is offline
Old 04-14-2006 | 07:20 PM
articfriends's Avatar
Seems like a IDEAL location because it would read a balance of all the cylinders on that side,Crockett had me install mine on the bottom of my manifold on a individual runner about 3/4 inch from a exhaust port. He said it wasn't the best spot but it would be fine,what do you guys think? Smitty
articfriends is offline
Old 04-15-2006 | 07:15 PM
nordic95's Avatar
Cobra,
I had a welder down the street from me do the work.He charged me 225.00 for both risers.He charges 75.00 per hour and that includes material.The only problem is that this is his first set and it took a little longer cause we had to figure on how to do it first.He also can not guaranty that the manifolds wont crack while he is welding them,Turns out these Revolutions Marines were no issue what so ever.PM me if you want him to do a set for you.
nordic95 is offline
Old 04-23-2006 | 10:53 PM
nordic95's Avatar
I finally got to fire one of my engines today and used my Innovate hand held O2 sensor with the wide band sensor mounted in my manifold.Worked like a charm to set up idle circuit.Next week I'll try water testing so I can get a full reading.This thing records 44 minutes of O2 readings and rpm readings and graphs them onto my laptop so I can see exactly what adjustments need to be done.I don't know how any one can set up a real world test without one.
Nordic95
nordic95 is offline
Old 08-04-2006 | 11:47 AM
Elite Marine's Avatar
You can't!!
Great job.
Elite Marine is offline
Old 08-04-2006 | 12:15 PM
SB
Smart thing to do . I can't see the pics so I can't comment on that.
Smitty - issue with your set up is that you have EFI (fuel source for each cylinder) and secondly,with it being so close you, with all that heat you may probably damage the wideband sensor quicker than normal.
SB is offline
Old 08-04-2006 | 05:20 PM
GOODT's Avatar
NICE WORK ....IM PROUD OF YOU!!!!!
Let me know how you make out with it!!!!!
GOODT is offline
Old 09-22-2006 | 09:27 PM
wwwTOPDJcom's Avatar
how to do this on a stainless marine setup?
wwwTOPDJcom is offline
Old 09-23-2006 | 11:55 AM
Nordic,
How did this end up working out for you? Any problems after a summer of use?
I was getting ready to make some spacer plates but this looks a lot more elegant. Are those aluminum risers?
thanks
bcarpman is offline
