Opinion on 37' Active Cat
Old 10-07-2003 | 03:10 PM
Default Opinion on 37' Active Cat
Found a 1982 37' Active Cat, an old race boat. I can get it for almost nothing. The layup looks a little rough, but no obvious damage.
My main concern is the weight. It seems to be a heavy hull for a cat, kind of like the old chris cats. I know it's the same design as the Benihana and War Cry race boats, but not sure about the layup.
Was considering supercharging a couple 502s, ZF trannys, and inline ASD6s.
Anyone have any experience with these hulls? Thoughts about them?
Gary
Gary Anderson is offline
Old 10-07-2003 | 03:22 PM
mikiedreb's Avatar
Hella heavy......but we were able to coax mid-teens out of Warcry with Merc 750hp EFI's running through crash-boxes and #5 drives. That thing could blast through some nasty water, but took a while to get up to speed.
Mike
mikiedreb is offline
Old 10-07-2003 | 03:40 PM
mikiedreb
Thanks for the resopnse.
If it's good for rough water, maybe it would make a good LOTO boat.
Do you know what the bare hull weighs?
Regarding weight distibution, the fuel tanks look like they're WAY far forard in the boat (ahead of the drivers. It also has a ballast tank up there. Is this the normal setup for these hulls?
So I'm guessing 550-600hp motors should push it to 90.
Gary
Old 10-07-2003 | 04:07 PM
PatriYacht's Avatar
What happened to this company? They used to be located near me in Algonac Mi.
PatriYacht is offline
Old 10-07-2003 | 05:15 PM
Gary-
Ask Kat Driver. I think he's ridden in one. As I recall he said it porpoised a lot: maybe that's the reason the weight is forward?
Dueclaws is offline
Old 10-07-2003 | 06:52 PM
mikiedreb's Avatar
Gary,
Warcry ran (4) 50 gal fuel tanks (2 pairs) just ahead of the engines between the cockpits. Nothing ahead of the cockpits. Never had any porpoising issues. Although it took a bit to get her on plane given the weight, she always accelerated straight and level. Barry had the rig weighed at a truck stop....12,000lbs with trailer. The trailer was a custom deal built by Jack Davision at Sanger .....for deep water launch...not light.
Given the performance with the 750's, you may be hard pressed to get it on plane and up to speed with any less horspower. I'd suggest blown motors for rec. use.
Mike
Old 10-07-2003 | 07:21 PM
mikiedreb's Avatar
Gary, question...
This Active that you're looking at wouldn't happen to be the old Panasonic boat from yesteryear, would it? I remember seeing that one in Redwood City years ago. White hull with red graphic, Arneson drives...
Mike
Old 10-08-2003 | 09:27 AM
mikiedreb
Nope, I dont think so. It's all white and used to have SSM Vs.
Sounds like it will need more hp than I want to invest in it. I knew it was heavy but wow, 12,000lbs on the trailer. Might as well get a 39' Aronow cat.
Gary
Old 10-08-2003 | 10:13 AM
BTW, mikiedreb
Welcome to the board.
Gary
Old 10-08-2003 | 01:02 PM
Mike J
Mikiedreb: You forgot a famous
Movie star won a offshore race
in "Warcry".
Remember me? Say HI to Paul A
Mike J.
