Another OSO member picks up a new 37 Active Thunder: >
Old 03-16-2007 | 02:40 PM
Default Another OSO member picks up a new 37 Active Thunder:
Congrats Macklin!
37 Excess AVH
525EFIs/XRs
Vinyl and Carbon Fiber cockpit
Audiophile Upgrade
Switchable Exhaust
All the bells and whistles.
Paint rendering is below. Many more details in the AT forum.
The boat will be in the Virginia Beach/Hampton Roads area in a matter of weeks.
Attached Thumbnails Another OSO member picks up a new 37 Active Thunder:-37.color-rend1.7.jpg
Old 03-16-2007 | 02:49 PM
Stormrider's Avatar
JC Performance Engines
I saw the boat when i was at the plant last month.
I was coming along real nicely.
Stormrider is offline
Son of a Gun's Avatar
Very nice. What kind of speeds can you see with a setup like that?
Son of a Gun is offline
Old 03-16-2007 | 02:52 PM
THEJOKER's Avatar
Nice Boats!
THEJOKER is offline
Old 03-16-2007 | 03:05 PM
87-88 depending on options. One of the non-liner 37s has done 90 w/ 525EFIs; light on fuel and friends.
Old 03-16-2007 | 03:18 PM
pm203's Avatar
How does the single step hull ride/ handle ?
pm203 is offline
Old 03-16-2007 | 03:33 PM
Excerpt from another thread in the OSO forum:
The way the dual-hull (DDC) rides is just indescribable. The step comes to a very sharp point at the very center of the keel; the line that is followed from the nose. From the step back to the transom is a somewhat flat pad, that has strakes built into it for accurate tracking. This basically allows the sharp point of the step to land first, and split the water in two, and then the pad carries the boat straight and level with no chine-walk/teeder. With such a dramatic single step, the boat ALWAYS, ALWAYS turns on this one step, at 30, 50, 70, 90 mph. Boats with multiple steps get into a disagreement with the driver on which step to pivot on, at any given situation, and this is how multiple step boats get out of shape in turns. I'll leave it at that. The AT is a single 4" step. Some of the other manufacturers are using 2-2" steps for the same level of efficiency, and angle of attack. Its a pretty well known fact that Cigarette and Fountain did NOT get their single step hulls right. Its a shame that too many folks think a single step does not work, just because they did not get it right. Again, all you need is a ride some snot to understand:
http://www.offshoreonly.com/forums/s...d.php?t=135904
The 33, 37, and 43 use the same design bottom. The 33 is literally a 9/10s scale version of the 37; not a blocked off mold. The 43 is also designed and tooled from scratch.
Here is some information on the architect of the DDC hull:
http://www.schoellmarine.com/innovations.htm
And the patent itself: High Speed Planning Hull Re. #36879
Old 03-16-2007 | 03:47 PM
pm203's Avatar
Interesting. Thanks for the info.
pm203 is offline
Old 03-16-2007 | 04:39 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Very nice looking paint. I know Macklin is gushing right now...
Reckless32 is offline
Old 03-16-2007 | 04:55 PM
BillR's Avatar
OSO Moderator
Brian,
I guess I am thickheaded, but I don't understand the liner delete? How is that possible? How do you make the boat as strong. How is the cabin built with and w/o? Why would want or not want a liner.
Looking for detailed explaination. . . . . . .
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
